other than a roll/pull what do i need for +8 in the rear to fit?
Im getting some ccw lm20's and they are 17x10.5 +8 in the rear. I was wondering if i needed a bit of a flare other than a roll and pull to make them fit. Also what camber do i need to make em fit and what tire size would you recommend to get somewhat of a stretch but nothing too sketchy.
thanks
thanks
You won't be able to tell the exact degree of camber needed to fit a wheel until it's mounted. But get hotchkis, or whatever give you the most negative camber. Do you mind rubbing? have you rolled and pulled at all?
You won't be able to fit a 215/45 on a 17x10.5...
You'll probably need a 235 or 245/40 maybe a 255/35 even. And you are gonna definitely need more than a roll and pull to fit something like that. Even if it was 17x9.5 with +8 you would have a lot of trouble fitting that with just a roll and pull. Definitely need to do a lot of modifications and run a decent bit of camber to get it to fit. If you have a stock body, honestly i'm not sure it is even worth trying to run these at all, you are going to have to do a LOT of modification.
scionlife
371
Jun 2, 2015 11:00 PM
carid
Jan 22, 2015 12:49 PM
