quick question (already searched)
Old Aug 10, 2006 | 02:29 PM
1badTc2-0's Avatar
Default quick question (already searched)
Can i fit a 18x8 wheel with a 45mm offset on my TC and not have any issues like rubbing or having it stick out past the fenders?
Thanks in advance
Old Aug 10, 2006 | 03:40 PM
TYPEII's Avatar
Go for it...No Prob...
Old Aug 10, 2006 | 04:37 PM
BOXMAN's Avatar
Yes but depending on tire size and if you plan on altering the suspension in any way?
You need to stick to a drop of around 2" and a tire of 225/40/18 as max size. I would also recomend going 35mm but 45mm will allow you to run spacers if you want
Old Aug 10, 2006 | 06:14 PM
krdshrk's Avatar
18x8 +45 offset is fine if you run 225 tires. +35 offset will rub imo
Old Aug 10, 2006 | 08:07 PM
1badTc2-0's Avatar
when i do suspension work, ill most likely go the TRD route or possibly coilovers depending on my money situation at the time. Im assuming TRD is not very aggressive with their drops
i wish the wheels i wanted came in a 35mm offset but they dont
Old Aug 10, 2006 | 08:24 PM
1badTc2-0's Avatar
i was thinking 225/40/18 kuhmo tires
Old Aug 10, 2006 | 09:12 PM
dex's Avatar
dex
+35mm will not rub. you may have to run a spacer with +45mm as it pushes all of the extra inch of width towards the springs. optimal is +40-35mm for an 8" wide rim.
Old Aug 10, 2006 | 10:34 PM
1badTc2-0's Avatar
thanks for the help. ill definetely plan to purchase a 5mm spacer
Old Sep 30, 2006 | 07:49 PM
Otocan's Avatar
O RLY?
I've got 18x8's +32mm and even with rolled fenders, I still rub with 225's on an auto-x course. (FYI the rear fender yielded 8mm, I measured, so even a +40 will rub stock)
Old Oct 1, 2006 | 05:10 PM
dex's Avatar
dex
O RLY?
well first i never said +32mm would work. and second if your rubbing in the rear with +40mm then your ride height is waay too low and your handling is probably worse than stock as a result. i run 18x8's with a +37mm offset and 225 rubber and im not even in the ball park of rubbing. i have run this setup in auto-x and on a few road courses so i have definatly put the suspension under alot of load.
S7ephavs
Mar 22, 2015 12:09 PM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
ShadowMage
16
Jul 25, 2004 06:02 PM
Sid_xBicious
Dec 31, 2003 05:39 PM
rodney_ray
Dec 23, 2003 08:41 PM
