tC Painted Stock Rims
Old Feb 27, 2009 | 05:18 AM
  #701
Mouse's Avatar
^^ dude... congrats on the house. thats a good feeling and worth celebrating.
Old Feb 27, 2009 | 05:20 AM
  #702
1989menace's Avatar
i think the blue actually looks good flintMicaTc. only some can pull it off. and it looks like u did!
Old Feb 27, 2009 | 05:23 AM
  #703
flintMicaTC's Avatar
thanks for the kind words, i feel i pull of the blue nicely, and a nice house should compliment it nicely haha
Old Feb 27, 2009 | 05:25 AM
  #704
Ro_Ja's Avatar
Everything goes better with a house.
Old Feb 27, 2009 | 05:32 AM
  #705
1989menace's Avatar
happy for you with a new house! lucky you.....i decided i still need to be patient with how economy is at the moment on getting my own place. same goes for modding my tc....rather save and not spend at the moment on a car....till things settle more and buisness speeds up....
Old Feb 27, 2009 | 08:02 PM
  #706
Jlowe's Avatar
Congrats on the house!
anyways, i recently got another set of stocks.
I'm thinking neon orange... though I have an rs 4 and not sure how that would compliment the silver linings. Any advice on a new color? Not black, silver or gunmetal. Any other colors?
Old Feb 27, 2009 | 10:04 PM
  #707
SW_08's Avatar
congrads
Old Mar 1, 2009 | 03:10 AM
  #708
bradaven's Avatar
that is an intense DIY... like it tho...
Old Mar 1, 2009 | 03:13 AM
  #709
Mouse's Avatar
um an "intense" DIY ? if you're referring to the rims... its really not that difficult. just make sure the prep is done, and done correctly and the painting process will be easy.
Old Mar 1, 2009 | 03:27 AM
  #710
bradaven's Avatar
ok ok... ha ha. I guess its not "intense".. Thanks for making feel retarded.. j/k. Just looks good and I would not, personally think about painting my own wheels with spray paint. Speaking of that, did you run into any adhesion problems since they have been painting. I know its very difficult to paint metal parts and get the paint not to chip...
Old Mar 1, 2009 | 03:31 AM
  #711
Mouse's Avatar
oh I wasnt trying to make you feel "retarded" by any means. but if you wanted to attempt to paint your own rims... just ask us experienced builders for some tips.... its all good bro.
Old Mar 1, 2009 | 03:36 AM
  #712
bradaven's Avatar
ha ha. aight will keep that in mind. so tell me then, how would I paint my billet grilles to keep them from chipping? primer and paint only or what?
Old Mar 1, 2009 | 03:46 AM
  #713
Mouse's Avatar
well... it doesnt really matter whether your base is a metal billet grill or the stock plastic.... concept is the same... do a good sanding with a fine grit paper by hand...say a 4-600 grit... nice and fine... this helps the first adhesion promotor get a good grip. Best pattern to sand in is a criss-cross (X) pattern. gives good even sanding. then depending on what kind of paint you're going to use... a primer isnt a bad idea... then allow time for the coats to dry between application... you dont want any "wrinkling" affect.... then you apply your top color coat...dont worry about getting every inch perfect on the first coat... build it up over a few coats.. gives even application.... then once fully dry...say at least 24hrs after final color coat.... then you can put on a couple coats of clear to help seal it. Hope that helps.
But first and foremost.... dont start the process unless the ambient air temp you're painting at is at least 70 degrees Farenheit...otherwise it's likely that the different coats all through the process will not cure correctly.
Old Mar 1, 2009 | 03:47 AM
  #714
Mouse's Avatar
oh and dont forget to completely mask off ANY area you dont want paint or overspray to get on.
Old Mar 1, 2009 | 04:39 AM
  #715
bradaven's Avatar
Thats definitely good advice. Thanks. seems pretty simple. Just gotta make the time to do it. Ill hit you up with the final project when I do it. I am actually buying a new tC next week so it will be on my new whip..
thanks again.
Old Mar 1, 2009 | 09:08 PM
  #716
Mouse's Avatar
rock on... keep us posted
Old Mar 2, 2009 | 03:31 AM
  #717
AretardedKID's Avatar
Old Mar 2, 2009 | 03:49 AM
  #718
breaux_tC's Avatar
looks good
Old Mar 2, 2009 | 04:07 AM
  #719
nebster's Avatar
yeah surprisingly enough i like the FM painted stockies
Old Mar 2, 2009 | 05:01 AM
  #720
rosedaleny806's Avatar
wow they do look good nice job man now u need to jus get rid of all the stickers lol
