what tire size should i get??
Old Oct 31, 2007 | 03:47 AM
sciontcnj's Avatar
Default what tire size should i get??
im looking to get some 18 x 7.5 Enkei Evo 5's with a 35 offset...what tire size should i get?
Old Oct 31, 2007 | 03:49 AM
Yanki01's Avatar
Old Oct 31, 2007 | 03:54 AM
sciontcnj's Avatar
thats what i was thinking....i just dont want them to look ridiculously stretched
Old Oct 31, 2007 | 04:00 AM
danoiboi's Avatar
225/40 won't look stretched.
Old Oct 31, 2007 | 04:14 AM
DonNguyen's Avatar
i'd get a higher offset too
Old Oct 31, 2007 | 04:23 AM
sciontcnj's Avatar
why? i want a sort of deep lip feel, its either +45 or +35 offset
Old Oct 31, 2007 | 04:29 AM
DonNguyen's Avatar
+35 is a rather low offset for the tC...if you're lowered, you might run into rubbing issues....
then again, you're not running a that wide of a rim...so you probably wont...
Old Oct 31, 2007 | 04:30 AM
sciontcnj's Avatar
makes sense don...i originally wanted to get some sport max 902's but ive heard bad things about the clear coat.
i know i wont run into any issues with the Enkei's like that
Old Oct 31, 2007 | 04:44 AM
danoiboi's Avatar
I might agree with don on this.
you'll be extending 16mm from stock position and risk rubbing with a drop, or extend 6mm (+45 offset) with no rubbing.
and if you have the money, you can always pick up 5mm spacers to make it "more flush" if you decide to go with a higher offset.
Old Oct 31, 2007 | 06:01 AM
Hyghgynx's Avatar
Default Re: what tire size should i get??
That's the PERFECT offset! I have a set of 5Zigens in the same size and offset. (225/40 tire size also.)
I'm on TRD Springs and incur zero rubbing. The only thing I would worry about is if you're lowered on S-Tech Springs.
Enkei is quality. Good choice on wheels!
Old Oct 31, 2007 | 02:00 PM
sciontcnj's Avatar
well ill roll the fenders then...since i am on S-techs.....
hyghgynx...lookin good bro
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
Jan 18, 2016 08:41 PM
scionlife
371
Jun 2, 2015 11:00 PM
kingofthecrate
Jan 21, 2015 09:28 PM
debris
Dec 16, 2003 11:50 PM
BUzzBUcket
10
Oct 12, 2003 07:19 PM
