widest tire for oem wheels
Originally Posted by thespottedcow
i was told i could fit 245/40s but they didnt make the tires i wanted in that low of a profile, so im running 225/45s, just go to a tire place, and they should be able to help you out.
thanks guys... i just hope i wont rub with 225s.. cause i am slammed and drive in Jersey with huge potholes... what if i do 225s in the back and 215s in the front? will that mess up the handling?
I wouldn't recommend doing that. If for no other reason, you are probably going to run directional tires (as those are the more performance oridented tires). You can't rotate tires left and right, so you have to swap the fronts and rears. If you have 215s up front and 225s in the rear, then you can't ever rotate your tires without unmounting. Thats just one reason.
Another is that the different sizes may throw off your traction capabilities as they will be uneven. Sorta like having 2 front tires that are different from the 2 rears. In this case, the rears will have more surface area on the ground, the front less. Therefore more traction in the rear. Well, just some things to think about. I don't recommend it.
wish i had those coilovers....
i im running 225's on 18's.
i would stay with 215 though...just because...lol
Because it's true.
Lots of people do stupid *hit, does that mean you follow their lead?
I have seen charts for tires up to 255 being used on a 7" rim, but my experience on motorcycles - which admittedly are very different - is not not go over the original size by more than one size.
In the end, it's up to you - but people need to know that premature wear and handling are affected by doing this.
Scott
Scott
Yea. Kungpao, I say that because it is truly NOT safe. i didn't say that its not doable. You can of course mount them on the rims, but there is a LOT of strain on the sidewalls of the tires and as I said, is just simply NOT SAFE. Just becuase people do it doesn't make it safe. Lots of people do stupid things.....Bush was elected president. The terminator is the governor of california. Get my point......
Lol, my bad. I just realized it's for OEM wheels. Yea that's totally right. I thought this was about the widest tire in general. With stock offset, I think 245 is the widest you can go. But definitely on a 7" wide wheel it's 225. My mistake! Sorry guys.
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
Beesh
Jan 9, 2015 06:30 PM
