Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
2014 10 Series light up Badges mod?
Old Oct 16, 2014 | 06:32 PM
stenger's Avatar
If I am not mistaking, 10 series badges are solar powered.
Old Oct 17, 2014 | 03:47 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
you are mistaken. they are wired into a power source.
the shift **** is solar powered
Old Oct 18, 2014 | 01:47 PM
G5_TC's Avatar
also im not sure about anyone else but the wiring diagram is in the glovebox
Old Oct 25, 2014 | 04:23 PM
torranosaurus's Avatar
Still trying to find an aftermarket setup for the front of my FR-S.
Old Mar 19, 2018 | 05:58 AM
DildoFightPack5000's Avatar
Originally Posted by torranosaurus
I have a new tC 10 series and am looking to make the front and rear badges stay on when the car is running. Anyone have any ideas on how to?
This isn't necessarily the best way to do it but it's not wrong by any means. If you want to be able to turn it on whenever you want, even if the car isn't running, the right way would be to go to the battery for power but then you have to run a wire through the firewall and that's a pain in the ___. The other options you have if you want to be able to turn them on when the car isn't running, is you can go to the ignition harness below the driver side dash and you'll find 12 volt constant in a big bundle of wires but you have to cut all the tape off the harness. Easiest way to get constant power for an accessory is from behind the radio. The info for the wiring of the radio is super easily available on the internet. Once you find your 12v+ and ground wire just strip the wire, poke it with a pick, stick the wire through, wrap the wire around the one your tapping in to, and tape it up, then add a zip tie to secure the wire to the one your tapping into (you can solder if you would like). And and run your wires. You'll need to add a switch in series on the 12v to the badge so it's not on all the time. And that's it easy least man...Good Luck!
____
Old May 20, 2021 | 04:31 PM
rvizcarrondo's Avatar
Default Scion tC 10 Series Badges/Emblem fuse?
Does any one knows wheres the fuse for this badges?
Both of them stop working and I click the bottom under the steering wheel just in case
this was the cause but is not working so I think is the fuse but I can't find it.
Any help please?
___
lunarcrusader
Scion tC 2G ICE & Interior
May 20, 2021 04:33 PM
14tC10Series
Nov 7, 2016 01:44 PM
MonsterunderBed0
Feb 17, 2015 08:42 PM
maxspiderx
Jul 30, 2014 02:42 PM
TealRice
Mar 27, 2014 02:34 AM
