Front Marker and Parking Light LED Install
Does anyone know where I can find a directory or video to show how to remove headlight and rear tail light so I can install LEDs for front marker and parking light?
Can you not reach them from under the hood? If not, you can usually get to them by turning the wheels all the way to the right or left and partially removing the splash guard to get to the light bulbs. Otherwise remove the front bumper and then you can fully remove the headlights. As for the tail lights I would think there would be some sort of access panel to remove to access the bulbs. I had a tC1 but never messed with a tC2 so I'm not positive. Either way they shouldn't be too difficult to access.
I can reach under the hood, it's just a tight squeeze. I was able to pull a brown/tan looking piece from the headlight which I believe was the front marker but I didn't want to pull too hard and break the piece or something. I might give it a try when I get off work and see if I can just keep twisting at certain angles.
For the parking lights. I'm not sure on where to start. I'll probably look into that more as well. Been working a lot of extra hours so my only day off is Saturday and I mainly used that time for some of the LED swap and plasti dip.
carid
Jan 8, 2015 11:33 AM
TheTripleC
Jan 4, 2015 06:46 PM
randode
44
Jun 29, 2004 04:19 PM
