Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
Headlight recommendations
Old Sep 6, 2013 | 12:56 AM
pro710's Avatar
Default Headlight recommendations
Sort of new to the mod arena. I notice that alot of the Gen 2 tCs running around my area have brighter/whiter headlights.
Are they running replacement bulbs or retrofitting the entire assembly? If so any suggestions as to the best replacement bulbs and where to buy?
Old Sep 6, 2013 | 01:16 AM
Raptor13tC's Avatar
I think that you are possibly talking about HID's, in that case they would just be replacing the stock bulbs with the HID bulbs, also you will need to find a place to put the ballast's
Old Sep 6, 2013 | 04:02 AM
jgj925's Avatar
your going to want this http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
Old Sep 6, 2013 | 03:43 PM
disaster06's Avatar
Go with the 35W, they are plenty bright, and I would go with 5000K. Gives a nice bright look without too much blue, when you use blue bulbs, you cant see too much and its more for looks. Plus, when the oncoming traffic is blinding you at night, and you look down at the road, the blue does almost nothing.
As far as a place to put the ballast, it is a small box about 1/2 inch thick, 2" x 3" and they give you double sided mounting tape and zip ties so its easy to find a place to put them. Then just plug and play into your old bulb harness
Old Sep 6, 2013 | 06:54 PM
pro710's Avatar
Thanks for the help guys!
So 35w? what bulb number does my '13 tC take and do I need to order any of those extra cables (mounting bracket, HID harness, error eliminator, adapter cables)?
Old Sep 6, 2013 | 07:04 PM
biglilsteve's Avatar
H11 is the bulb type. you don't need any other accessories. just the basics that come with the kit.
i am running two pairs of HIDs (projectors and fogs) and they both operate just fine with out any of those accessories.
Old Sep 6, 2013 | 08:36 PM
MadFunnyBruh's Avatar
quick question mate, how did u wire the HIDs in fogs? Like balast placement?
Old Sep 7, 2013 | 12:26 AM
The lead coming from the ballast, combined with the lead running from the bulb make a pretty long cable.
I was able to place the driver side fog ballast taped to the side of the battery, and the passenger side fog ballast secured near the windshield washing fluid reservoir.
Old Sep 7, 2013 | 12:30 AM
You could grab some of these as well to aid in ballast placement if you still need more length.
http://www.theretrofitsource.com/pro...ducts_id=14162
Old Sep 8, 2013 | 09:14 PM
pro710's Avatar
So most people are running HID conversion kits (like DDM) instead of just changing out the bulbs?
Old Sep 8, 2013 | 09:45 PM
yeah, you need to actually need to go HID in order to see a noticeable difference. i first swapped my OEM bulbs for Sylvania SilverStar Ultras (high-end halogen bulbs), and i noticed a slight increase in brightness...however, you can get a reasonably priced HID kit (like DDM) for the same price.
Old Sep 9, 2013 | 12:19 AM
pro710's Avatar
Cool. Thanks B L S!
Old Sep 9, 2013 | 12:29 AM
My man.
Old Sep 9, 2013 | 07:51 AM
thnx a lot =)
hampton1100
May 28, 2015 07:32 AM
carid
Apr 7, 2015 02:21 PM
Wolfgang94
Mar 24, 2015 12:48 PM
S7ephavs
Mar 22, 2015 12:09 PM
scsteven
Jan 25, 2015 01:06 AM
