I need answers asap
Old May 17, 2013 | 03:40 AM
dannycruz's Avatar
Default I need answers asap
I need to know what fliuds should I get for best results .... motor oil? ATF? Brake oil? Antifreeze fluid? Im doing it all by myself but I need to know what I can buy at autozone I need good answers asap thank u guys
Old May 17, 2013 | 04:17 AM
Klope1's Avatar
Use mobile 1 synthetic (verify with dealer that they used synthetic and not regular), ATF type should be listed in owners manual for the type, and regular DOT 3 brake fluid will be just fine. for the ATF it might be better to take it to a transmission shop so they can use the machine to flush it out. How many miles do you have on the car? you shouldn't have to do ATF flushed until 60K to 90K depending on how you drive. ATF should be checked every 30K.
Old May 17, 2013 | 12:20 PM
dannycruz's Avatar
I have 31997 miles on it
Old May 17, 2013 | 07:45 PM
Klope1's Avatar
If you get it serviced at the dealer there suppose to check all the Fluid levels and make sure everything is ok. should be no reason to change the ATF. When you did your brakes did you bleed out the brake fluid?
Old May 17, 2013 | 10:14 PM
SonicDRKNITE23's Avatar
Ya especially with tranny fluid. U have to much tranny fluid it could really mess up your tranny. Btw I changed mine at 80000 miles so u will be fine
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
user9430961
Sep 24, 2015 01:09 PM
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
