Overheating problem on 2012 tC. Only one fan runs..
Old Jul 9, 2018 | 05:10 PM
Andy9093's Avatar
Exclamation Overheating problem on 2012 tC. Only one fan runs..
I recently bought a 2012 Scion tC. The other day the red coolant light was blinking. I noticed the ac having a problem with cold air. I was stuck in traffic in 100+ weather.
I turned the A/C off and drove home with no more over heating light. I got Home popped the hood and checked. I saw only one radiator fan running. Turn the air back on, checked the fans again and only the one fan was still running.
This is is what I have done:
I’ve replaced the relay for the fans so I know they are good. I've ran direct power from the battery to the fan that wasn’t coming on. It turns on perfectly.
I've switched the plugs for the 2 fans and drove it to see what would happen. Only one fan came on still. It’s the other fan though because I switched the plugs for them
The only other thing I can think of is the coolant temperature sensor. I ordered one and it will be here Wednesday. I don’t see how that would only turn one fan on but I could be wrong.
If anyone has any other opinions please let me know. Also i tried looking for this in the threads but could not find anything. if this problem has been solved please give me the link.
Thank you.
Old Jul 10, 2018 | 01:03 AM
Andy9093's Avatar
Update
i did some more test on it today. I used a multi volt meter to determine if the relays are all good and they are.
i test to see if there is continuity from relays to connection ports, there is, and is also receiving 12 volts
Old Jul 13, 2018 | 12:01 AM
Andy9093's Avatar
Another update
i replaced the coolant temperature sensor and still hasn’t solved the problem. Only one fan is still coming on
Old Jul 15, 2018 | 05:10 PM
Maxbeachbumb93's Avatar
I had the same problem on a similar car. I replaced the entire fan assembly which I got at my local parts store and it solved the problem!
Old Jul 16, 2018 | 02:34 PM
drizzoh's Avatar
I've had similar issues from previous cars and the fan controller is what had gone bad. I don't know that the tC has one though, not one I've seen anyway. Which fan isn't running, the radiator fan or the condenser fan?
bobbymo
Scion iQ Drivetrain & Power
Aug 23, 2018 03:31 AM
Andy9093
Jul 9, 2018 02:54 PM
Forced4
Aug 25, 2015 08:18 PM
Juanja
Sep 19, 2014 04:00 AM
hardlucktattoo
71
Oct 19, 2011 05:31 PM
