Radiator coolant flush DIY?
Old May 30, 2018 | 06:24 PM
oblivionlord's Avatar
Default Radiator coolant flush DIY?
Anyone know if there is a tutorial DIY for the 2AR-FE on this 2G Scion to flush the radiator and replace associated parts such as thermostat?
Old May 31, 2018 | 03:40 PM
drizzoh's Avatar
Not really a DIY, but page 34 on this shows some details about the motor and where the thermostat is located: http://www.rav4world.com/pdf/2AR-FE.pdf
Old Nov 5, 2018 | 04:06 AM
Well its been a few months and hardly anyone has pitched in except one person. You'd think there'd be more participation from existing owners other than myself that actually want to provide to the tC2 community instead of using tutorials from other Toyota vehicles on other websites.
Old Nov 9, 2018 | 02:52 PM
drizzoh's Avatar
This forum is dead af, but it's a coolant flush.. just open the reservoir, remove the drain plug and drain the coolant from the bottom of the radiator (it has a drain bolt) and then fill it back up.. There's not much to it. You can run distilled water thru the system to really flush it out, but unless you have a pump that's not the most fun thing to do. As long as there aren't a lot of sediments in the coolant you should be fine just draining and refilling.
Spencertimm
Aug 27, 2018 04:48 PM
sciontc_mich
11
Oct 5, 2010 08:07 AM
Spect2K3
11
Jul 18, 2007 10:58 PM
kronicillusionz
Mar 5, 2007 11:25 PM
yellot00tr
24
Jan 6, 2006 04:02 AM
