Scion tC 2G Forced Induction Turbo and supercharger applications
Custom Turbo
Old Dec 12, 2011 | 05:52 PM
danGtc's Avatar
I actually had a 5E-FHE with a ct9 on it (which I eventually upgraded to a td04l). I learned a few things from that experience which may be helpful.
1. The CT turbos are... ok. They are heavy, thrust bearing, and top out around 18 psi. It seems sort of small (It was well matched on the 2.0L MR2).
2. Once they go it's hard to find rebuild kits. Mine died in spectacular form, shooting oil out about three feet in the air from the blow off valve. It was pretty cool. This might be less of an issue on the ct26 as it's more popular stateside
3. The flanges are different from many popular turbos, limiting upgrade/replacement potential
4. Prices on good turbos have dropped a lot, so it's easier to justify spending a little more and getting a solid BB turbo with a popular flange fitting.
All that being said, they are solid turbos with a bit of a following. I probably wouldn't do it, but if you want to go for it :D
Old Dec 13, 2011 | 12:28 AM
yardleyTC's Avatar
Originally Posted by talt2008
+1 for the OP! hopefully everything works out for you on boosting your ride. keep updates about the build because im interested as to how this will all pan out
Thanks man, as soon as the headers come in from ebay and we redo the welding and that the work will restart can't wait tho for sure.
Old Dec 13, 2011 | 01:42 AM
youngflyer's Avatar
i was unaware that ebay even has a turbo manifolds on there for the GEN2. I didnt think its been out long enough for someone to copy.
Old Dec 13, 2011 | 01:44 AM
danGtc's Avatar
You can always buy a NA header and lop off the flange. It's a bit ghetto and the turbo ends up oddly low, but it works on a budget.
Old Dec 13, 2011 | 02:39 AM
youngflyer's Avatar
Oh god that is very ghetto and sounds like it's more hassle than its worth
Old Dec 13, 2011 | 02:50 AM
yardleyTC's Avatar
http://www.ebay.ca/itm/GSP-SCION-TC-...item5ae3567ffa
heres one.... there are hundreds online
Old Dec 13, 2011 | 04:13 AM
youngflyer's Avatar
Dude that is for a 2az...did you check that the head on the az and the AR are the same
Old Dec 13, 2011 | 01:55 PM
TC-Maverick's Avatar
its says camry on there.. I thought we have a camry engine.. ?
wiki:
"The AR engine family is a straight-4 piston engine series by Toyota, first introduced in 2008 for the RAV4, and subsequently for the Highlander, Venza, and Camry.
The AR series uses a die-cast aluminium engine block and aluminium DOHC cylinder head. The engine series shares many of the technologies in the AZ engine, while incorporating new features such as continuously variable valve timing on both intake and exhaust camshafts or dual VVT-i.....The AR engine replaces the AZ engine."
^^^ I'd be optimistic about this..
Maybe not enough to personally spend the money on a part that may not fit properly.
But, I'd like to think in the transition between these engines Toyota would minimize the number of things they have to change in the production process for cost concerns. So Hopefully the size/shape of the ports as well as bolt pattern and spacing around the exhaust ports are the same..
Old Dec 13, 2011 | 03:06 PM
youngflyer's Avatar
My guess is that we have a completely different head
Old Dec 13, 2011 | 03:47 PM
yardleyTC's Avatar
I've been told it fits.
Old Dec 13, 2011 | 08:37 PM
youngflyer's Avatar
^ call kareem as descendant motor-sports and ask just to double check. The might also have a turbo manifold for the 2AR that you could purchase...who knows?!?!
Old Dec 13, 2011 | 08:43 PM
GUNNIST14's Avatar
yARDLEY JUST make sure the turbo manifold lines up with the studs and then tighten it down. Make sure there are no clearance issues that would cause exhaust leaks.
On the Ct9 I personally have no experience running lower spec/size turbo's but for the 2AR 2.5 it will need atleast a moderately sized turbo IE. T3/T4 57 trim,16G,Precision 5431 or 3431 and so on. You are definitely acquiring the CT9 at low cost but I wouldn't recommend it. You will hit 6psi far too quick to enjoy boost and end up upgrading anyway.
Just get a 16g or turbo similar and have the ability to go higher if you wish.
Good luck man the 2AR has great potential.
Old Dec 13, 2011 | 08:53 PM
GUNNIST14's Avatar
Just looked at the Greddy blog for there time attack TC and the head does look slightly different to the 2AZ so you might encounter some problems mounting the old 2AZ turbo manifold.
Let us know how it turns out.
Old Dec 13, 2011 | 09:32 PM
danGtc's Avatar
He said ct26, a ct9 is tiny.
The head was the main thing that was redesigned in the 11+, getting vvt-i and an acis manifold. I doubt they are the same, but it would be awesome if it is.
Old Dec 13, 2011 | 09:41 PM
yardleyTC's Avatar
Ill let everyone know if it fits when it comes in! If not I have a few days to return it and no harm done!
Old Dec 13, 2011 | 09:44 PM
..... awaits results...
Old Dec 14, 2011 | 04:47 PM
yardleyTC's Avatar
placed the order for the headers...due to being in the great white north the shipping will take a while at the holiday season will update upon arival!
Old Dec 14, 2011 | 06:40 PM
Hayseed's Avatar
Why the hell are you ordering headers for a turbo build? This thread is confusing, op has no clue what hes doing
Sent from Somewhere using Something.
Old Dec 14, 2011 | 07:03 PM
you cant bolt the turbo to the head...
Old Dec 14, 2011 | 07:26 PM
Hayseed's Avatar
Lol. No ____ Sherlock. By definition he'd be buying a turbo manifold. A header and a turbo manifold are two different things.
