Scion tC 2G ICE & Interior In-car entertainment and electronics...
DIY: Stopping rattle in drivers door.
Old Nov 30, 2010 | 06:14 PM
reccoso's Avatar
Default High Bass and Panel vibration
Anyone else vibration noises from the door panel when listening to music? Mine does that when the volume isn't even very high, but as long as there's some heavy bass, I hear it. Now I had my windows tinted recently, and i think they remove door panels for that, could that have caused any issues?
Any remedies??
Thanks
Old Nov 30, 2010 | 07:28 PM
Papa_Bear's Avatar
No it was not the removal of the panels as mine does that and I have yet to do anything to the car still. Its just something it does from the factory. I'm going to take it to the dealer so they can fix it. I'm sure this is a common issue on our cars
Old Nov 30, 2010 | 07:35 PM
DustinMorrisTC's Avatar
Mine has the same issues. Let me know if the dealership is able to do anything about it.
Old Dec 1, 2010 | 12:43 AM
Superpickel's Avatar
pull the window control unit out. See if it wibrates then...
Old Dec 1, 2010 | 06:06 AM
greenbean24's Avatar
Some experimentation with dynamat might also be helpful
Old Dec 1, 2010 | 06:19 AM
eugenyz's Avatar
Yup same problem, if u check i posted a few days ago about this problem on the same forum. I put in new speakers and used sound deadenign material, it only helped a little. If u guys want to fix it yourselves you have to glue the housing to the window controls solidly to the door (as this is what is causing the rattle). Now i have absolutely no rattle. But let me know what the dealer says im curious. take care.
Old Dec 1, 2010 | 08:09 PM
Papa_Bear's Avatar
If the car was not brand new I would probably pull the panel or pay for dynamat but it shouldn't have this issue and I'm not going to mess with it if they will take care of it for free
Old Dec 1, 2010 | 10:12 PM
biglilsteve's Avatar
I hear that...i'll be waiting for a post with a dealer response!
Old Dec 31, 2010 | 01:01 PM
WellesleyScion's Avatar
Default DIY: Stopping rattle in drivers door.
Hey guys, I started to get the rattle in the door about a week ago, and decided to look into it.
The panel that is rattling is the one that has the window switches on it.
Time: ~1 minute
Tools required: 1 piece of paper, hands
-Pop the panel up and then slide it toward the rear of the car to remove it.
-Take a piece of paper and tear it to be a little bit shorter than the length of the panel between the handle and cloth arm rest.
-fold the paper length wise twice so it is 4 layers thick
-tear the paper again to be about an inch wide.
-place the paper on the edge of the door panel and crease it over the lip towards the outside of the door
-pop the window panel back onto the door
-you may have to finagle with the paper to keep it in place so its not visible when the panel is on
After this turn up the volume and smile cause the rattle is gone
Old Dec 31, 2010 | 04:57 PM
OpTiMi5t's Avatar
Team Sushi
if you get a chance you should include pics into this DIY that way im sure the mods on here to get this stickied into the tech section
though im not a 2nd gen tC owner, i do appreciate the time you did putting into this and being open to help other scion owners
good job!
Old Jan 1, 2011 | 03:19 AM
VVTinme's Avatar
If this is a widespread issue hopefully Toyota will release a TSB. Having to wedge paper in the door seems like a real poor man's way of doing things.
Old Jan 1, 2011 | 05:06 AM
Don't knock the poor man's way, its the code we live by...
Thanks for the ghetto fabulous DIY. I know it will make 87% of us happy. The other 13% can wait for a recall...
Old Jan 1, 2011 | 05:09 AM
VVTinme's Avatar
Recall =/= TSB.
Believe me though, if mine starts rattling and the dealer can't fix it someone's going to find his printer down a sheet.
Old Jan 1, 2011 | 05:34 AM
ChefJefftC's Avatar
I would also love a couple quick pics maybe, just so I am absolutely sure I understand what your explaining in your post...does not have to be fancy...I am just a visual kind of person...also could you theoretically do the exact same on the passenger side, cause I may be getting a slight slight rattle on that side as well with heavy base sometimes.
Old Jan 2, 2011 | 02:33 AM
excaka's Avatar
i second the pics . also can u be more in depth i have this rattle on both sides and it ticks me off. i also noticed tonight i have a rattle behind my air conditioning vent above the stereo deck. it only rattles when i hit 38 mph exactly and accelerate when its there. ugh
Old Jan 2, 2011 | 05:52 AM
Duct tape fixes all...
mans motto = if you can't duct it, f*@^ it
Old Jan 3, 2011 | 04:25 AM
donsun's Avatar
hm, will try this fix when I find the time. definitely hear the rattle when cruising on the highway and have the stereo on pretty loud. only solution so far was to either turn down the bass or to rest my arm on the door
Old Jan 3, 2011 | 01:01 PM
LOL, guys... total time is like less than 30 seconds to do this fix... literally pull the window switch panel up, shove paper on the edge, pop panel back on...
ill snap pics when I go on lunch today...
Old Jan 3, 2011 | 04:01 PM
ChefJefftC's Avatar
lol, he is right...I know I was one of the ones that asked for pictures but I didnt have my car with me at that moment and was having a hard time visualizing it. I got home and took a look and ended up doing it to both sides in about 5 minutes...piece of cake...thanks wellesley
Old Jan 3, 2011 | 04:33 PM
No problem :D
