Scion tC 2G ICE & Interior In-car entertainment and electronics...
DIY: Stopping rattle in drivers door.
Old Jan 4, 2011 | 04:17 PM
reccoso's Avatar
Originally Posted by WellesleyScion
Hey guys, I started to get the rattle in the door about a week ago, and decided to look into it.
The panel that is rattling is the one that has the window switches on it.
Time: ~1 minute
Tools required: 1 piece of paper, hands
-Pop the panel up and then slide it toward the rear of the car to remove it.
-Take a piece of paper and tear it to be a little bit shorter than the length of the panel between the handle and cloth arm rest.
-fold the paper length wise twice so it is 4 layers thick
-tear the paper again to be about an inch wide.
-place the paper on the edge of the door panel and crease it over the lip towards the outside of the door
-pop the window panel back onto the door
-you may have to finagle with the paper to keep it in place so its not visible when the panel is on
After this turn up the volume and smile cause the rattle is gone
Thanks for this, it's one of the most annoying things about the car, even at moderate volumes you can hear a rattle.
I wonder though if there's a more long lasting solution, and a more waterproof solution than paper. I know 3M makes many sturdy double-sided tapes in different thicknesses, I wonder if they would be any better.
Old Mar 7, 2011 | 05:41 PM
donsun's Avatar
LOL, guys... total time is like less than 30 seconds to do this fix... literally pull the window switch panel up, shove paper on the edge, pop panel back on...
ill snap pics when I go on lunch today...
whatever happened to these pictures? I'll probably try and do this today or tomorrow. anybody else find an alternative solution in the meantime?
Old Mar 7, 2011 | 05:44 PM
WellesleyScion's Avatar
LOL, It would be a waste of e-tree's to post the pics.
Old Mar 7, 2011 | 05:49 PM
donsun's Avatar
aw i guess i'll figure it out myself then. are there any tabs that may be prone to breaking
Old Mar 7, 2011 | 05:58 PM
Nope, just grab and pull.
Old Mar 9, 2011 | 04:52 AM
moonman_55's Avatar
has anyone actually called their scion dealership and had them fix this?
Old Mar 18, 2011 | 01:56 AM
messyjesse87's Avatar
So I attempted to "pull the window switch panel up" and it gave me some beef... I broke the clip at the front of the panel... And now it rattles even more....
Old Mar 18, 2011 | 03:36 AM
madspar's Avatar
That sucks.. Someone should really post pics of how to do it fast, safely, and easily.
Old Mar 18, 2011 | 03:47 AM
XerotC's Avatar
this. shouldnt warranty cover it and any DIY would only mess with or void the warranty?
Old Mar 18, 2011 | 04:46 AM
Can I buy the piece that I broke? I hate having broken pieces in my brand new car.....
Old Mar 18, 2011 | 05:32 AM
MightyP's Avatar
Should have the part number on there somewhere. TRD sparks might have it. Otherwise you can always buy stuff from the dealer
Old Oct 26, 2011 | 02:41 AM
lilmerz68's Avatar
remove the window switches and try some clear silicone around the edges worked for me
Old Oct 26, 2011 | 05:59 AM
topher86's Avatar
I checked with my dealer about it and they said they would create a case about it but did nothing to fix it......GGGRRRRRR.....
Old Oct 26, 2011 | 10:21 AM
KidJustin's Avatar
DaYUUM/Scion Evolution
the issue is really a design flaw in the audio system...all of the high bass is going into the door speakers...mainly the lowest woofer
the only "real fix" is to change the audio system so that the bass is redistributed throughout the car and not just on the doors....with that said, the OEM Audio+ Reference 400CF does this, once this system is in...no more rattle (based on experience)
Old Oct 26, 2011 | 01:05 PM
noisy1eh's Avatar
We have true 8" in the doors and when we first fired the system the door panel was alive to say the least. with only a hand full of clips and a couple of screws no were near the 8" speaker its a vibrating panel that is going to happen.
It got better when we removed the the panel and drilled the rest of the holes in the 8" grill but a lot of sound deadener in the doors and the back of the panel helped a lot.
We have over 200 sq of deadener in the car and still have not completed the roof as of yet.
Saying the speakers being changed stopped the vibration is very questionable
to say the least, that says that the speaker before it was playing x range and the new one is now playing y range and no other changes made.
The car from the factory sounded………………. and lacked up front bass and highs over 8khz. adding highs is easy but the bass is very hard and people have been installing subs and raising crossover points for years to get the bass sound but coming from the rear of the car for years.
Like some one said you can dab the lower conners of the doors as a quick fix to help hold the panel down.
We are running our 8" at 65hz up to 280 ish the 4" are 200is up to there upper range and the tweets are about 6khz up and only with the 8" set below 50 does the 8 and the door rattle like hell because of rear waves in the door and air space required for the 8's
Old Oct 26, 2011 | 02:33 PM
Talk about raising the dead...
Old Oct 26, 2011 | 02:35 PM
Rotz's Avatar
It is almost Halloween....
Old Nov 4, 2011 | 01:41 AM
ebaklid's Avatar
i have two 12" in my trunk and it was rattling like crazy back there. when i looked into it it was a broken clip flying around in there so that could be it.
Old Nov 14, 2011 | 06:31 AM
ruben7475's Avatar
i took mine to the dealer and the said they couldn't find where the problem was coming from..
Old Nov 14, 2011 | 09:40 AM
Blackedout011TC's Avatar
It is the power window switch housing.. Put your hand on it with the music cranked, it should go away. The housing just pops out. A bead of non corrosive silicone around the edge will stop it. Best solution, throw a 12" sub in the trunk so you can turn down the bass on the head unit. This will significantly reduce the vibration on the dooor switches. Then let the sub drown out the rattles. Adding one mediocre sub and amp made a huge difference in sound quality.
