Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Scion tC Brake Clunk?
Old May 11, 2019 | 02:31 AM
flight90's Avatar
Default Scion tC Brake Clunk?
A clunk coming from the rotor, there's no way to insert bolts into the holes....
These are Aftermarket rotors...
help anyone?
______________________________
Last edited by MR_LUV; May 11, 2019 at 04:29 AM. Reason: Moved to Correct Forum by Administrator
Old May 12, 2019 | 10:54 PM
62Fender's Avatar
Those threaded holes are to assist removing stuck disks from rusty hubs. They're not mounting holes. The clunk might be a bad wheel bearing (if tightening the lug nuts to 76 ft lbs doesn't stop it.)
Old May 13, 2019 | 02:27 PM
drizzoh's Avatar
The 'clunk' looks like it's from the rotors sliding on the hub. This is normal as there are no rotor bolts to secure the rotors to the hubs. You shouldn't have any clunking with the wheel properly torqued as that's what holds the rotor on. Double check all the suspension bolts and especially the endlinks if you're noticing any clunking, but the rotor behavior is totally normal.
Swbari00
Scion xD Suspension & Handling
May 25, 2012 01:47 PM
DirtyAstronaut
25
Jul 28, 2011 02:02 PM
3min3m2
13
Mar 22, 2008 03:11 PM
TrappedInABox
Nov 21, 2006 09:03 PM
mFrosty
Scion tC 1G Wheel & Tire
Sep 5, 2006 02:35 AM
