black headlights
Old May 9, 2007 | 12:16 AM
firebadbobb's Avatar
Default black headlights
ok, this post is broke into 2 questions. where can i find a good tutorial for baking headlights? i want to open it up and paint the inside some. all these newfangled clear headlights confuse me. i want alot of black inside, but i dont want to mess it up by painting the wrong thing. so what can i get away with? trust me guys, this is going to be tight.
Old May 9, 2007 | 05:02 AM
nuvs's Avatar
try the search section dude !!
There is a nice write up about this topic.
Old May 9, 2007 | 06:00 AM
Zillon's Avatar
https://www.scionlife.com/forums/vie...465&highlight=
https://www.scionlife.com/forums/vie...740&highlight=
https://www.scionlife.com/forums/vie...683&highlight=
https://www.scionlife.com/forums/vie...802&highlight=
Try those.
And try the search function.
Old May 9, 2007 | 10:14 AM
Narcolepsy123456's Avatar
I've done it a couple times on celica headlights, but i'm guessing since they are toyota, they should all be the same.
remove any metal screws you can to start with on the outside of the headlight, also any of the rubber fittings that are on the back.
preheat the oven to 350 degrees then turn it OFF. insert headlight for 13 minutes, but keep an eye on it just in case. take it out, it will be super hot, so i suggest using mechanics gloves, and pry it apart using a sturdy tool. be very careful with the black tabs that connect to the clear part. any good cleaner/solvent can clean up the excess silicone, I use PPG's DX330.
Old May 9, 2007 | 08:28 PM
wow, this is a really good reply, thx! sorry bout the no search thing. "bad firebadbobb, bad!!!
Old May 9, 2007 | 08:35 PM
Neothin's Avatar
https://www.scionlife.com/forums/vie...el+eye+install
Old May 10, 2007 | 01:52 AM
Zillon's Avatar
I prefer doing them at a lower temp, 250 @ 12 minutes worked fine for me, and there's absolutely no risk of melting anything.
Also, use a piece of cardboard to insulate the light itself from the pan in the oven.
Old May 10, 2007 | 09:23 AM
all of these tuts are great for baking, but how much of the chrome can i paint in the middle? or does the chrome inside need to be there for enhancing the light? also, do i use high temp paint because of the heat?
Old May 10, 2007 | 12:59 PM
you cannot paint any of the cup behind the light or the chrome cover in front of the light, the side trim peices are fine to paint however.
Old May 10, 2007 | 02:50 PM
Zillon's Avatar
I suggest just painting the piece that wraps around thhe outisde. It will pop right off of the regular bucket. You'll just need to mask off the turn signal bucket.
Scuff it with steel wool, mask off the turn signal, clean it with rubbing alcohol to remove oils, and spray 2-3 light coats of Duplicolor sandable filler primer on it. After that, lay 3-4 coats of Duplicolor acrylic matte-black automotive paint.
Old May 17, 2007 | 05:54 AM
Viace's Avatar
ill do it send em to me
Old May 18, 2007 | 01:38 PM
Blue_Batmobile's Avatar
cool.
Bat™
Old May 19, 2007 | 01:44 AM
comedykills's Avatar
ScionERA
Scionetics
is this what you want to do?
Old May 19, 2007 | 02:00 AM
motz's Avatar
heres mine.
it wasnt hard as i thought it would be.
i also reccomend to take the orange plastic corver thing for the turn signal.
you can pop it from the back.
and for the painting, do not paint the reflactor.
i saw someone painted the whole thing and ended buying a whole new headlight
cuz the light output was so low after painting.
this is another thread
https://www.scionlife.com/forums/vie...109&highlight=
and video of my headlight
http://www.youtube.com/watch?v=_hEtZ2ljMe0[/img]
Old Jun 5, 2007 | 04:02 PM
techick's Avatar
Beccari just did this to his headlights. They look hot, I can't wait till we can do mine
Inazuma
20
May 3, 2023 01:58 AM
mischman
Mar 31, 2015 03:16 AM
stenger
Mar 29, 2015 08:03 AM
umnitza
Dec 1, 2014 06:26 PM
