2004-2006.5 [NCP61]
How to change passanger side mirror in scion xA 2006
Old Jun 16, 2009 | 12:11 AM
sh00zkosmosu's Avatar
Default How to change passanger side mirror in scion xA 2006
Does someone has a instruction how to do it?
What tools do i need?
Anybody did it before?
Is it difficult?
Any help will be much appreciated!!!
Thanx in advance
sh00zkosmosu
Old Jun 16, 2009 | 04:51 AM
STEELBREEZE's Avatar
If you are just changing the whole mirror, all you do is pop off the lil triangular black intrior piece on the inside of the door behind where the mirror is. It just pops straight off. Then use a 8 or possibly 10 mm socket to remove the 3 nuts from their studs that hold the mirror in place. You may have to remove the door panel to get to the end of the wire lead for the power remote connection. Push in the snap lock for the electrical socket and disconnect. Be sure and support the mirror when removing the last nut so the mirror doesn't fall and scratch the outside of the door. Then install the new mirror and reverse all other operations. It might take all of 5-10 minutes depending on if you need to remove the whole door panel to reach the wire connections. It is super easy. Again, the black triangular piece just pulls straight out to pop off. It only has 1 or 2 snap points. I have done it in less than 5 minutes before.
Old Jun 19, 2009 | 04:37 AM
Extremely easy job indeed
Socket size is 10 in case anybody might need it in the future.
Thanks for input.
Old Jun 19, 2009 | 06:23 AM
Hope it helped a lil.
Old Jul 11, 2009 | 12:48 AM
wilsonl313's Avatar
How do you remove the door panel? I've tried to remove it but I haven't been able to just pull of the panel after unscrewing an anchor type screw along the side where the hinge is, then another where the handle is, and another in the part of the door that you hold to close it. Is that all the screws or are there more that i just can't find?
Old Jul 11, 2009 | 05:15 AM
the rest are just snap clips. You have to pull hard around the lower edge. Make sure you pull off the lil triangular piece behind the outside mirror first.
XirtaXa
24
Jan 14, 2025 03:49 PM
Kiwibox
Dec 15, 2014 09:46 PM
minter66
Dec 15, 2014 01:45 PM
PTUNING
Dec 11, 2014 08:09 PM
Male_Nurse
13
Mar 10, 2008 02:51 AM
