2004-2006.5 [NCP61]
Scion xA : Issues and Problems... More Found (08/01)
Old Nov 8, 2007 | 04:56 AM
Persocon's Avatar
my front bumper is just like yours, misaligned on the right side.
my headlights are also dim. I'm guessing it's how the electrical is setup to have too long of a power wire to the headlights leading quite a bit of voltage drop and thus losing output.
One thing you can do is to buy those Silvanias bulbs from most major chain autopart store. It's the ones that cost 40-50 dollars and comes in a fancy well packaged case.
What ever you do, please do not buy HID kits. They will only blind oncoming drivers.
Old Nov 8, 2007 | 01:31 PM
stonecoldnimrod's Avatar
the only noticable problem i've has just recently is a little squeal from my engine. might me the belt.
Old Nov 8, 2007 | 03:22 PM
Dispatcher138's Avatar
Default Re: Scion xA : Issues and Problems... More Found (08/01)
Originally Posted by Unicron
First, let me start off by saying that I LOOOOOOOOOOOOOOOOVE my xA... I stare at it during my 15 minute break and 30 minute lunch. However, I'm having some... well, issues and problems. I divided them into two categories... issues for not serious and problems for serious... please help...!
Issue
Not so much a problem as it is a slight issue... but the steering wheel buttons are a LOT dimmer than the stereo and HVAC... and the "AUTO" button for the driver's side window glows, but you can barely see it... even in complete darkness.
Is anyone else's like this...?
Issue
The dash material blows. I purchased a Turtle Wax dash sponge to grab the dust and the texture of the dash ripped the sponge to shreds...! It gets dusty easily and it's near impossible to clean because of the texture... even lint free cloths leave something behind!
What do you guys use to clean and treat the dash...?
Problem
Right side of bumper is slightly ill-fitting... where the bumper meets the wheel arches on the side of the car... there's a slight gap and is not flush like the other side...
Is this a problem that the dealership will take care of...?
Problem
Ground my gears trying to get into reverse (it's sloppy). Ground my gears a few times trying to downshift from fifth to fourth.
Anyone else experiencing this...?
Problem
Sometimes there's no power or boost in power after I upshift... the gas pedal gets firmer and more resistant... but little power delivery. Happened 3 or 4 times so far.
What do you think could be the problem...? Clutch...?!
Problem
The headlight beams have VERY little reach...! And on the highway, I can see EXACTLY where the light reaches. It let's me see maybe 20 feet in front of me and that's it. It ends abrupty... no vanishing point. Exit signs pop up quickly...! And the lights don't illuminate the highway signs...! Very dangerous! Going 40, I've always had to break abruptly for pedestrians because I don't see them till near the end...
Did the service department not adjust them when I took delivery?
I see this is a little old but still throw in some insight. The wheel controls are dim thats why I'm going to have someone put new leds in there. The dash is wierd but after drying the outside with a microfiber cloth i wipe the inside off because its fairly damp and works like a charm. when reversing sometimes i will notice it catch and make alot of noise which is wierd because the car isnt moving and the engine is at idle. In reference to the headlights...thats why I bought HID's
Old Nov 8, 2007 | 03:24 PM
I have seen some that yes do blind people and others that dont. It depends how the glare is and how they are aimed. HID's FTW
Old Nov 8, 2007 | 06:51 PM
dand's Avatar
Also, the long piece of silver trim on the center console is loose, but I think that I can super glue it...
I wouldn't super glue that if I were you. If ever you want to replace the stereo head unit etc, you need to remove that long silver piece in order to access two screws that hold the center console in place. The long silver part is only held in place by some plastic snaps, so try just pushing it back in if it's loose.
Old Nov 9, 2007 | 12:51 AM
Persocon's Avatar
notice I said HID Kits
HID FTW only if it is a proper retrofit with OEM HID projectors.
Old Nov 9, 2007 | 11:24 AM
oook well I said HID's ftw I meant the kits also considering you cant just throw the bulbs in there with the kit....but to each his own.
Old Nov 19, 2007 | 03:06 AM
xadustin's Avatar
I'm starting to wonder if my car has poor build quality... I told you guys about the bumper issue. Well, today I noticed that my right rear passenger door does not close flush... the door part does, but starting where the window begins, it doesn't. It comes out and is quite visible, though I'm not hearing wind coming from it or anything. It's completely flush on the other side.
Anyway, I've got the imperfect bumper and the side door. Will they cover this under the warranty?
My first new car purchase is chocking up to be a disappointing one... or am I overreacting and these are just new car niggles?
This is just my opinion, but problems that you can't fix yourself, easily, should be pointed out to the dealer. That is what the 3/36 warranty is for. I know how it is with your first new car. My first brand new one was a Matrix in '05 and I would have said the same thing. One door leaked, one held water, and the horn stopped working, and had an intermittent starting problem. All in the first month, which made me worry about reliability. Window molding replacement fixed the leaking problem, but had to be replaced again in the future. Door holding water had tape over the drainage holes. Horn was improper wiring. ECU software problem on the starting. After that the car was great! Just took getting the bugs worked out. Moral is, if you have a problem take it in. Thats what they are there for.
As far as the xA. Knock on wood. I would say the build quality is a hundred times better! Bought it with 26k in March and now have 45k on it and I would say it runs the same as the day I bought it. (with the exception of some things from a *minor* ;-) accident I had in it.)
Old Nov 19, 2007 | 05:37 AM
Lately mine doesnt want to start as quick as it usually does in the cold. the lowest it has been over night was like 30 something....
fluxingnation
Dec 26, 2014 04:28 PM
mdhyre
Dec 7, 2014 12:52 AM
silverslider
Dec 1, 2014 11:18 PM
randomsuper
Nov 27, 2014 04:05 AM
Jamster
Nov 20, 2014 07:49 PM
