2004-2006.5 [NCP61]
what engine oil and how long
Old Aug 20, 2012 | 12:57 PM
Maineman's Avatar
Default what engine oil and how long
So Im bored at workso I thought Id throw this topic out there. I have been working at a local Jiffy lube for 5 years as an inspection mechanic and have learned alot about lubricants. sadly I only see 1-2 xas a year and usually owned by old people lol. So I thought id put the ? Out there what oil do you use and how many miles between service.
I run mobile1 0w-20 and go 6k I have 120k in my 05 xa. I also changed the manual trans fluid to mobile1 75w-90 when I replaced the clutch.
Old Aug 20, 2012 | 10:06 PM
jpn6438's Avatar
I run royal purple 5-30 with 10k between change.
Old Aug 21, 2012 | 07:32 AM
jct's Avatar
jct
5w30 pennzoil platinum every 5k which lasts me about a year on one oil change
redline oil MT-90 every 30k miles for my transmission
kaleco blinker fluid
Old Aug 21, 2012 | 07:35 AM
Archangel1183's Avatar
Wow, that's super thin oil for 120K. Also, are you guys using Synthetic or why are you going so low between Oil Changes? 10K sounds like too long, even for synthetic.
I run regular 10W-30 and replace it every 3K. My XA has 133K Miles.
Old Aug 21, 2012 | 09:28 AM
Maineman's Avatar
0w-20 synthetic is thin and I wouldnt rec. for most cars over 100k but this motor is something else lol it still purrs like brand new and most of the miles are highway over 3k rpms so I wanted an oil that would flow, lube, and cool the best. 6k is alittle early I could easily go 10k where its highway miles but its free so I do it lol. The oil is usually just starting to turn dark at 6.
Old Aug 21, 2012 | 11:31 PM
taman86's Avatar
the new camrys use 0w-10 i think. it helps with emissions and fuel mileage supposedly cutting down on engine parasitic drag and increasing effeciency. however, run manufacturer specific with the most current API rating, which at this time is 'N'. doesnt matter if its synthetic, synthetic blend or standard motor oil, as long as the back of the bottle has the most current rating. persoanlly i run full synthetic.
06ScionTc5sp1
9
Oct 16, 2020 01:18 AM
Col168c
27
Apr 9, 2020 10:48 PM
Col168c
9
Jan 7, 2016 06:55 AM
Col168c
Jan 8, 2015 06:30 PM
eric_m
79
Mar 17, 2013 12:21 AM
