06 xB Not Cranking, No Radio, No Headlights, some Dash Lights..
Old Mar 29, 2020 | 09:51 PM
Historiis's Avatar
Default 06 xB Not Cranking, No Radio, No Headlights, some Dash Lights..
It has over 300,000 miles so I'm not sure putting more money into it is worth it, but I'd like some opinions first. It was running fine because I just changed the plugs and coil packs then the check engine light came on during my commute.
I was going to check it the next day but when I tried it in the morning I got nothing. No crank, no headlights, no radio, no brake lights, dash lights did come on. Battery is good but was dead; charging did not help situation.
I can't get it to shift into Neutral. Checked every fuse, they're all good. No idea what to do.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Mar 30, 2020 at 12:12 AM. Reason: Moved to Correct Forum by Administrator
Old May 17, 2020 | 10:38 PM
TGYK000's Avatar
I had a similar issue when I relocated my battery in my 05 xA the issue may be a Ground problem. The Ground cable for the battery (if it's in its original location) should split off to 2 points
one on the core support and one on the transmission mount (if memory serves) if one of those aren't making a good connection it could lead to that issue.
___
Old May 18, 2020 | 03:14 PM
62Fender's Avatar
Consider a battery and alternator test. AutoZone will do it for no charge.
dubbinandlovin
Jul 27, 2016 02:01 PM
muttman
Scion tC 1G ICE & Interior
9
Oct 14, 2014 11:56 PM
pioneer1976
Mar 22, 2012 05:39 AM
Doos_is_wild
Mar 2, 2012 07:28 AM
jallamas
Feb 15, 2008 06:18 PM
