ackward noise when pressing clutch pedal?
your clutch pedal runs on a small lever system. right where the pedal connects to the firewall, there is a joint there and over time it will slowly dry up and start squeaking every time you press down on the clutch and every time you let go of the clutch. it's just a wear noise... just like the rear seats. the back supports, there they latch to the two metal latch points on the sides. there is a plastic covering there that once it wears to the metal, a god offal squeak noise will come up and it will be like driving an older 80's style blazer where the rear window hinges would start squeaking a week after you bought it brand new...
park it, take a can of WD40, get under the dash area there and spray a bit into the joint. move the pedal in and out for a bit to work the oil in there. i bet ya that will fix it... cause it fixes mine... and mine constantly gets squeaky with what i do.
i will gladly post pics on monday when i get my xB back from the body shop.
