Add aftermarket Cruise Control?
Always check out the parts section of the forum. There are usually some testimonials there on parts:
https://www.scionlife.com/parts/?sub=86
Re: Add aftermarket Cruise Control?
Originally Posted by LMO
Hello all. I'm a newbie. Had my Xa about a month. I really like Cruise Control and am thinking about adding one from Rostra. Anyone have any experience with these?
Thanks!
LMO
Thanks!
LMO
I installed the Rostra Cruise Control myself. I wasn't that hard. I didn't have the RF controlled but the stalk. Overall, it works pretty good. Took me the better part of an afternoon to do it. Some of the wiring was a little hard to get to but overall, it is a well designed kit. Check the Allscion.com site about installation tips for the cruise control. Most people with common sense should be able to install it.
I have an 06 xA with the Rostra cruise controll. It was installed by SE Toyota Distributors before being shipped to my dealer. Most of my daily commute is interstate driving at 65mph. It works great, and I'm glad I have it.
My Toyota/Scion dealers here (Hawaii) won't install it. That's why I'm asking...
Was the Rostra CC installation pretty easy? Most I've done on a car is an oil change, change bulbs, etc. Do you need mechanical experience to install?
Thanks.
Thanks.
LMO, Not really. You can look at the instruction manual and see if you can do it. If you can install a stereo, you should be able to do it. There is no special tool that is needed. Just basic screwdrivers, sockets, and pliers (As far as I can remember - I forget things in my old age).
Was the Rostra CC installation pretty easy? Most I've done on a car is an oil change, change bulbs, etc. Do you need mechanical experience to install?...
I decided NOT to do it myself, but took it to a local experienced installer who did it with two guys in 45 minutes for $150. The reasons I did not try it myself: (1) too tall and stiff to spend the time required up under the dash, and (2) cannot turn my bifocals upside down to see connections that are 4" from my nose always looking upward under the dash.
People will tell you installing the CC is a piece of cake. My advice is to do what I did:
1. Get the info on a local installer recommended by AllScion before you buy the CC from them.
2. Check out the installer yourself -- the first one they gave me was on the BBB blacklist.
3. Read up on the installation before you buy.
4. Do a dry run after you buy, laying it all out, tracing the routings, sighting all the connection points.
5. Decide who is going to install, before you get your car messed up and can't finish it.
Beesh
01-09-2015 06:30 PM
fugeelama
19
01-24-2004 07:03 PM
