Bypassed rear O2
I just put in a simple circuit to bypass my rear O2 sensor. The circuit makes the ECU only see the last image captured into the ECU , of the O2 seeing clean air. You don't need to mess with the front one because it only runs the engine. I did this to the rear O2 to keep the ECU from trying to reset itself. Most of the Scions on here running the Cam-Con know our ECUs try to relearn stuff all the time. The rear O2 only has one main job and thats clean air. If it gets a really wierd reading then it will throw eveything into limp mode and throw a check engine light. Now if I change a setting on the Cam-Con telling it to richen it up the ECU will not try to fight it.
actually the rear O2 sensor tests the efficiency of the catalytic converter by measuring the air after the cat and comparing this to the front O2 sensor
it does not come on until the car is in closed loop
Team No Limitz
yea...the camcon should normally override the settings of the ECU and alter the A/F ratio, but thats when you start throwing the CEL's...I plugged in my OBD sensor today and magically had 3 new codes pop up all having to do w/ my MAF sensor not being able to adjust for the amount of air being blasted into the throttle body.
so how do I go about doing this override, I am not running a cat. and I have CEL, TRAC OFF, and VSC lights that stay on. Car runs fine, I think it is running a little rich though, sometimes I can smell gas at the exhaust tips.
try a o2 sim. What kind of car?
stillcole
Scion tC 2G ICE & Interior
Apr 6, 2015 03:42 PM
clickclickw00t
Feb 18, 2015 08:57 PM
