Engine stuttering
Old Apr 27, 2023 | 07:35 AM
JayB's Avatar
Default Engine stuttering
Took my 04 xb out for a quick trip to the corner store, on the way hone she started sputtering and seemed to have real lack of power. no engine codes. Located here in Medford Oregon.
Old Apr 27, 2023 | 12:40 PM
armygreenxb's Avatar
How's the car been maintained and how many miles? Lots of things to check - fuel filter, air filter, MAF sensor, throttle body.
Old Apr 27, 2023 | 01:26 PM
LULU's Avatar
Probably need more information and details about the car. Auto/Man? Smoke or anything leaking?
Old May 4, 2023 | 10:53 PM
okokray's Avatar
max air flow sensor ??
Old May 6, 2023 | 03:34 AM
sh0rtlife's Avatar
a sudden stutter and no codes really only points at 2 things air or fuel, specificly, did something "move in" to your air box, and have you recently been running the tank low?...running a fuel tank to neer empty will cause all the crap in the tank to get sucked into the filter, but it also causes the fuel pump to run hot, and can cause low pressure
thats my 2 cents without any extra info
Old May 7, 2023 | 08:57 PM
DannoXYZ's Avatar
Moderator
Moderator
vacuum leak. Sucking in extra air that's bypassing MAF and not being measured.
Codes only pop up when something's failed and sending out-of-range signals. In this case, MAF is being tricked, but still sending out OK signals. Just doesn't match actual air-flow conditions
Old Jul 15, 2023 | 11:27 AM
EileenTucker's Avatar
Thanks for the advice, sir. I will keep it in my mind.
Old Aug 8, 2023 | 12:03 PM
You made my day, your advice is helpful.
Spoiler
Shiroi
47
Feb 11, 2015 11:06 PM
johnmk
9
Oct 14, 2011 01:05 PM
Rocket
Mar 29, 2006 01:03 AM
SciFly
12
Aug 25, 2005 06:42 PM
woof
10
Aug 18, 2004 11:12 PM
