Exhaust vs. Power Gain
Yes, but only after full exhaust to the cat. Not just the axle back. The oem mid pipe is only an inch in diameter. So an axle back wont do much if you keep the oem mid pipe in.
I would put in a high flow cat, but dont want to mess with the o2 sensor. I need to do header and downpipe and that should make it better.
After I put the 20's on, I noticed a significant loss of power from a dead stop, and much slower accelleration at low rpms, so im looking for more power. Any suggestions under $500?
The problem lies in the fact that the engine system is already pretty highly tuned and optimized for midrange and lowend torque. Mods to the exhaust and intake give some gains at the highend, often at the expense of the lowend, which is where you have a problem...
The same thing happens with 4WD vehicles and huge mudder tires, usually solved with compensating ratio gear sets in the diffs. Neither cheap nor easy, and likely not available for a scion...
95% of the exhaust systems out there for the xB are "axle-back." You'll probably see a 2-3 hp gain at best. Most of the exhausts out there are chosen for the style and sound more than anything.
The 5% available that are cat-back are from Magnaflow, Borla and Precision Muffler. These typically run from 1.5 to 2 times the price.
If you get an axle-back and want to replace the mid-pipe it is not a bad idea. Just remember, there is really no need to replace the cat. It flows just fine, and buying a "high flow cat" would really be a waste. Just remember is you have a custom mid-pipe fabricated at a local exhaust shop, have them add a resonator as well. The factory exhaust has a resonator, and keeping a resonator helps maintain a clean, lower tone.
Also, if you add a header in the future and good exhaust shop can also fab up a larger diameter down pipe. The only company that currently has a downpipe commercially available is Precision Muffler. Just keep in mind that if you buy one from them, you will still need to have it welded on. So you're probably looking at a trip to the muffler shop anyway.
I'd say that Thermal has always been known in the import world for making some of the best performing exhausts. Fujiz.com has the Thermal catback exhaust for $490. Check into that one...I've heard it gives noticeable gains.
carid
02-09-2015 01:49 PM
JM Auto Racing
12-19-2014 06:36 PM
Phillip_Injen
53
01-17-2004 01:56 AM
DjFrOsT
9
10-03-2003 03:43 PM
