idle timing screw
does anyone know if there is an idle timing screw that adjusts how much the butterfly is open in the throttle body at idle?? my 88 corolla gts had one and i could adjust the idle that way, i want my idle up about 200 rpms, its kind of low and dips periodically
Idle speed is controlled by the computer by bypassing air around throttle using an electrical valve. If you adjust trottle stop screw it will change signal from the trottle position sensor and you dont want to mess with computer inputs. So basically this is not how idle speed is corrected. Besides that the transmission will be affected also (auto or manual - doesnt matter)
If the car has a problem with idle then try to find the source. Like a vacuum leak, loose air ducts, bad idle speed motor etc.
Bakoscion46x
Jan 19, 2015 02:39 AM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
