Jammed gearbox 1st Gen..
Looking into buying a 1st Gen, 5-Spd manual, but seller states that it won't go into first gear because of a jam in the interior gear box.
I've been looking on forums and on YouTube to try and see what it'll be like trying to fix, but can't find anything.
Any help, advice, links would be appreciated
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; 02-06-2019 at 05:13 PM. Reason: Moved to Correct Forum by Administrator
See if they'll knock $200 off the price and that should cover any work the shifter might need as far as failed plastic pieces or bushings. If there's more to it and there's actual transmission issues with the car I'd walk from it unless you can find another tranny and replace it relatively cheap.
See if he'll let you take the car to an independent mechanic for an inspection on your dime.
And second gear starts will finish off the clutch pretty quickly too.
LBTc06
02-18-2006 12:26 PM
