New Turbo Kit for the XB
Team No Limitz
I had talked to the guy a while back through emails...he never once release a price or date when the kit was coming out...I have a feeling they are running into some problems w/ fuel. long term fuel trim kills everyones hopes and dreams unless you got extra injectors or standalone
Originally Posted by Yaris_WRC
wraith, would i be right in saying that if you got 145hp @ 5psi with a 10.5:1 CR if you lowered the compression ratio you would make more power at the same pressure?
because lower compression means more room for more air+ fuel ???
Now if my motor was say 9.0:1 comrpession it would be more responsive and can easily make more power with less boost. But I would be riding the fine line of detonation and a blown motor.
You have to understand ... The turbo is technically raising your compression by compressing the atmosphere air that your motor is use to ingesting ... Normally, Your motor ingest air thats atmospheric and then when it gets in the combustion chambers. It gets compressed with the fuel mixture.
so wraith would the manifold with the PSI kit be reliable?
it would seem so.
ok here is one for your imaginary calculators:
@5psi it give 144 whp keep that to one side. now who knows about the EIP turbo'd echo that was ment to be running @ 12psi on stock internals at 10.5:1 CR i forget exactly how much power it was ment to be making... can anyone remember?
im not sure and i might be wrong but was it not 175WHP? and it had a TECIII ECU i think. i cant remember if that was at the wheels or not/ but i think it was using a T3 turbo.
now with all that info who would like to guess how much a 1NZ-FE would make with a T3 turbo + 8.5:1 CR and 15psi with stand alone ECU (all using a front mount intercooler)???
Originally Posted by Simplyscion
I will stick to my cast iron manifold...I will feel a lot safer knowing the chances of cracking my mani are slim to none.
cessblood
Sep 15, 2015 06:50 AM
my06tc
Jun 25, 2015 12:18 AM
