Scion xA Manual Tranny Seal leaking..Help!
Hey there Scion Aficionados!!!
I've recently replaced both Axel's and seals and the passenger side seal is leaking.
Seal is flush to the trans.
Any suggestions?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Any suggestions?
Last edited by MR_LUV; 07-03-2020 at 05:44 PM. Reason: Moved to Correct Forum by Administrator
If the seal is leaking and has been replaced, I'd imagine:
I ended up buying a set from the dealership and the LH and RH seals were different part numbers.
A quick look on Toyotapartsdeal.com shows the LH as 90311-34022 and the RH seal as 90311-34023.
Hope this helps.
____
- Install issue
- Wrong seal
- Bad seal
Hope this helps.
____
N8dogg12
08-06-2017 11:00 PM
cpuslave
10
05-17-2014 04:43 PM
iheartzombies
03-05-2012 04:20 PM
Blue_TC_Man
04-19-2009 11:48 PM
