Help Please! - 2005 Scion xA Evap
Old 06-07-2018, 09:23 PM
turbodonut99's Avatar
Default Help Please! - 2005 Scion xA Evap
2005 Scion xA, 175k, P0441, P0442, P0446.
Used a fogger to locate leak, was leaking from mating surface (where the gas cap and filler neck meet), replaced gas cap and still was leaking, so I replaced the filler neck, now the pending codes come on in about 3 days (about 80 miles) when it use to take about a
10 minute car ride to throw a CEL. I have also replaced the rubber hoses going from the motor, to the sensor, to the steel line and the one on the canister that leads to the steel line, still throwing the same 3 codes! If anyone can shed some light on this!
Thank you.
Last edited by MR_LUV; 06-08-2018 at 05:25 AM. Reason: Moved to Correct Forum by Administrator
turbodonut99 is offline
Old 06-08-2018, 02:00 AM
jct
jct's Avatar
start with replacing the charcoal canister if the codes still there replace the purge valve in the engine bay
jct is offline
Old 06-08-2018, 02:48 AM
well i would like to diagnose it before i start purchasing parts especially expensive ones
Old 06-11-2018, 01:24 AM
jct
jct's Avatar
i tried doing that, nothing i did was able to fix it total p.i.t.a. when electronic solenoids fail...
jct is offline
Sgtusmc98
11
10-24-2018 12:19 AM
nickhenry
05-10-2017 01:07 PM
Xavior
01-16-2015 12:53 PM
Jet111111
02-25-2013 08:53 PM
Quick Reply: Help Please! - 2005 Scion xA Evap
