Screeching belt when it's wet out
Old 12-03-2018, 12:21 AM
Flyover's Avatar
Default Screeching belt when it's wet out
After it's rained or really just any time it's wet out, some belt in my 2006 xA screeches for about the first 3 minutes after I turn it on. It doesn't seem to matter whether I'm D or N (haven't tried R, I don't think) or what my RMPs are or whether my foot's on the break or accelerator. Then after about 3 minutes the screeching noise just stops on its own, usually at the red light at the end of my street.
Is this something I should fix because it's serious, or is it something I can fix if I want to because it isn't serious?
*Note: xA Engine questions are Combined into the xA/xB 1st Gen-Drivetrain-Power Sub-forum
______________________________
Last edited by MR_LUV; 12-10-2018 at 05:17 PM. Reason: Moved to Correct Forum by Administrator
Flyover is offline
Old 12-03-2018, 01:08 PM
Super Moderator
SuperMod
MileHightC's Avatar
Given that a screeching belt isn't 'normal', I wouldn't ignore it. I'm guessing your belts are either worn, glazed or stretched a bit. Check the belts for their current condition and tension and go from there. I'm sure your neighbors will appreciate it.
MileHightC is offline
Old 12-04-2018, 01:56 PM
jimmyess333's Avatar
I may be showing my age here but back when V belts were common there was a "belt dressing" in a spray can for noisy belts.
Of course check that your belts aren't just loose first.
jimmyess333 is offline
Celliator
15
04-03-2013 05:41 AM
kevbayer
02-21-2013 10:13 PM
bskicrash1
11-28-2011 12:55 AM
cpuslave
11-29-2010 03:26 AM
puggo63
10
07-24-2009 02:18 AM
Quick Reply: Screeching belt when it's wet out
