So... My underdrive pulley fell off!!
Old Aug 18, 2006 | 04:19 AM
kms_tuning's Avatar
Default So... My underdrive pulley fell off!!
If you get an aftermarket underdrive pulley on your car make sure you use loc tight. I'm here to tell you, because mine fell off.
Old Aug 18, 2006 | 03:06 PM
Fujiz_xb's Avatar
sIcKsCiOnS
that mega sux.
Old Aug 18, 2006 | 09:16 PM
metal112524's Avatar
FELL OFF???? .... LOCK TITE!?!?!?!?
Old Aug 19, 2006 | 05:41 AM
SwaTx21's Avatar
i actually had that problem too. on the tech for installing one it says hand tighten it, so i didnt wanna bend it or anything tightening it too much. the little pin that aligns it bent and was wobbling all over the place. ive got pics of it if anyone wants to see it. pm me. it cost 18 cents to get a new pin. can you belive that???? ripoff.
Old Aug 19, 2006 | 05:57 AM
kms_tuning's Avatar
Thats alot better than the $2600 I am spending for a new crankshaft for Scion, However there is a possiblity it will only cost $500 and they can replace the pin. Either way it totally sucks, I am car-less for the next few weeks and have wasted alot of extra money on a $100 dollar part. I have decided to never modify my scion again, after this incident.
Old Aug 19, 2006 | 09:01 PM
well dont do that you can just do interior exterior.. you know if it aint fast it better look good ( why do you think are cars are slow)
Old Aug 19, 2006 | 09:12 PM
Tomas's Avatar
Admin Emeritus
I've heard so many 'horror stories' about problems caused by aftermarket pulleys that I would never even consider adding one to Vanilla.
Old Aug 19, 2006 | 09:33 PM
yenzlife's Avatar
does this happen to any other of u out there?? im putting my on soon, i dont ever want it to happen to my car, i going use tread lock, thx for the posting .
Old Aug 30, 2006 | 09:41 PM
Emfdiablo's Avatar
My pulley fell off...twice, then the dealer wanted to charge me 2200 dollars to fix it, i told them it wasnt me, i had the stock one on at that point, and they fixed the car, but hen it was on the dealers dme, they fixed it without taking apart the engine...hmmmmm. I think theres another fix than the over 2 grand crank replacement fix.
DO NOT GET A CRANK PULLEY, it will eventually fall off. Mine took over 6 months to show its faults.
Old Aug 30, 2006 | 10:20 PM
pandaslayer's Avatar
ummm, I'm scared. I put on a lightweight pulley about a month ago.
Old Aug 30, 2006 | 10:39 PM
Satmax's Avatar
I'm actually glad I saw this, I was close to getting one...
If you are really bent on putting one on the car, is it possible to use safety wire or a cotter key to keep hardware from becoming loose?
Old Aug 30, 2006 | 10:57 PM
bB384's Avatar
IV ACE
Honestly, I think it was probably the way it was installed, (maybe you didn't tighten the bolt well enough?) I bought the Perrin pulley for my car back in January this year and I've been checkng the bolt and it hasn't even loosened let alone fall off. I know others who have/had pullies on their cars and they never had this problem. I put my car through abuse in the canyons always bouncing off the limiter and still no loose pulley.
Old Aug 31, 2006 | 12:46 AM
kaotic1's Avatar
Ok guys, has anyone else had this problem? I had planned on putting my new Perrin pulley on tomorrow. Now you all have me extremely nervous about it. Lets here from the people who have had an aftermarket pully on for a while with no problems. (Hopefully there are some)
Old Aug 31, 2006 | 01:02 AM
boogi_man's Avatar
is this an actual underdrive? or is it the lightweight cnc'd aluminum?
Old Aug 31, 2006 | 07:51 AM
yenzlife's Avatar
I put mine on 2 weeks ago, i used tread lock, and i made sure i tighten the nut, i use long extend metal pipes so that the braker bar and a screw driver to hold the pulley from spining while tighting the nut can slight into the metal pipes to extend the power while u tighten the nut, u have to tight the nut as much as force u taken the nut off, thats the only way to make sure its TIGHT, if u dont tighten it, or u THINK u tighten it, that means u DIDNT, it will full off because it a moving part . i mean DEAD TIGHT by extend the length of the tool ur using , its the best way to tighten it, unless u have SUPERPOWERED ARM.
Old Aug 31, 2006 | 08:39 AM
itsme's Avatar
i've had my perrin for well over 6 months now with no problems
Old Aug 31, 2006 | 08:45 AM
yenzlife's Avatar
did u put it on urself? if so how did u tighten urs?
Old Aug 31, 2006 | 09:10 AM
itsme's Avatar
yea i put it on myself took me about an hour or so cuzz it took me a bit to figure out what i was suppose to do going on what i read in the forums but i got it done........ i used air tools i didnt hand tighten anything cuzz i couldnt even take out the bolt by hand so why would i hand tighten i couldnt take out by hand.........but yea i just used air tools for taking out and putting in
Old Aug 31, 2006 | 11:12 AM
jct's Avatar
jct
i used all hand tools and i even torqued it down too spec just was a p.i.t.a to do too
Old Aug 31, 2006 | 11:29 AM
bB384's Avatar
IV ACE
Read my post I posted right before you.
