squealy alternator
what makes it squeal like that it happens maybe like 3-7 seconds at most maybe lil longer when i have every thing on like the head lights the fan on the setting of 3 or 4 music some what loud and a powered sub its not a sign that the battery is going?
and its not my belt
and its not my belt
Sounds like your belt.
Yes I read the post above me, and your saying it wasn't your belt but it is!
Maybe the belt is tight but it is glazed making it slick? Everytime mine starts making noise I tighten it up and it goes away.
Mine squeals like mad when it's damp outside and the temperature is just above freezing. I just put up with it, since it's not that bad-- once the car runs for a few seconds, it goes away, until next time the engine is cold.
Here's the book answer:
6. ADJUST FAN AND GENERATOR V BELT
(a) Insert the adjusting bar between the engine RH mount
bracket and generator. Push the bar towards the vehicle
front to adjust the V–ribbed belt tension.
NOTICE:
Do not insert the bar between the oil control valve and generator.
It could damage the oil control valve.
(b) First tighten bolt A, then tighten bolt B.
Torque:
Bolt A 19 NVm (189 kgfVcm, 14 ftVlbf)
Bolt B 54 NVm (550 kgfVcm, 40 ftVlbf)
Bolt A is the top alternator bolt. Bolt B is the bottom one, and a royal PITA to loosen. Toyota does not define the length of the "adjusting bar", what I use is an extended length crowbar, 36" I think. Basically you need more leverage.
if you have a way of checking belt tension, it should be measured between the alternator and crank pulley, and give 11 to 13 mm at 340 to 440 N*M of tension.
NOTICE:
Torque:
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
SJMiller
Sep 12, 2015 06:33 PM
