Stafford Fabrication turbo kit
Old Sep 21, 2004 | 02:18 PM
superjeer's Avatar
Why was the post linking to the civic forums deleted? This is not a sponsered sales thread. sfp isn't even a site sponser. I'm looking forward to this kit, but we can't delete negative threads for no good reason. If there IS a good reason then please replace the post with that reason rather than just deleting it outright. My understanding is that post had merit.
Old Sep 21, 2004 | 02:57 PM
rotarycolt's Avatar
Originally Posted by sfpower
well i'm back from the dyno and vwe could only run 6.6 psi do to the week base spring on the wastegate but we picked up 85% i'm looking for alittle more so i'm changing the wastegate and going back tomarrow!
weak spring? is it pulling open under boost? Mine does that... lol... junk actuators.
Anyhow, what are the chances of you selling me a manifold w/ a deltagate 38mm flange???? I want to fit a gt28rs on the damn thing, and I have a deltagate sitting right here... i'm tired of this small smooth turbo ____... i want something serious.
Old Sep 21, 2004 | 03:34 PM
Spider13's Avatar
I agree. There defiantly was interesting info over there. :?
Old Sep 23, 2004 | 07:31 PM
Spider13's Avatar
So whats the word? Did you get it fixed and run it again?
Old Nov 11, 2004 | 05:06 PM
sfpower's Avatar
well its been awhile we've been realy busy and we finally got back to the scion xb. the kit is completed and gigged for duplication. it is currantly set at 6.5 psi and producinig 130 hp and 132 tq. to the ground on an auto .we will be going back to the dyno in a week and a half to do the final programming for the kits. boost is only a couple a weeks away from being an affordable option.
Old Nov 11, 2004 | 10:02 PM
rotarycolt's Avatar
Not bad at all...
Old Nov 15, 2004 | 12:50 PM
Jays05EchoHB's Avatar
Only 130whp? That's not much at all.
the car has what..~95whp stock? My Focus had 105whp stock and I was runing 220whp daily..I guess I was expecting the same % power increase.
What are you using for fuel management?
Old Nov 15, 2004 | 05:05 PM
squirrel's Avatar
I think its down around ~88 whp.
Old Nov 15, 2004 | 07:03 PM
empleh's Avatar
isn't the focus a 2.0L or a 2.2L? 1.5L in the xB........
Old Nov 15, 2004 | 07:55 PM
squirrel's Avatar
aaaah, yup. something like that.
Old Nov 15, 2004 | 08:07 PM
hotbox05's Avatar
dyno a manual. much better. alot more accurate numbers for most of us power hungry folks out there
Old Nov 15, 2004 | 08:08 PM
hotbox05's Avatar
most xb's with manuals get 92 whp stock
Old Nov 19, 2004 | 10:10 PM
rotarycolt's Avatar
Over 100% gain w/ a bolt on kit with no internal mods? Something sounds a little far fetched.
Old Nov 23, 2004 | 10:10 PM
WAFFLES's Avatar
interested in more info.
I've been asking for a while, can someone tell me what the stock injectors are rated at?
What was the fuel management for this setup?
Old Nov 23, 2004 | 11:06 PM
rotarycolt's Avatar
Stock injectors are around 200cc, I have changed mine out for 2zz-ge injectors, which are 310cc.
Old Nov 24, 2004 | 03:29 PM
WAFFLES's Avatar
thank you sir. are these a peak and hold or saturated?
I'm sure 270cc is more than sufficient to support 200whp. :D
Old Nov 25, 2004 | 12:30 AM
BoostedRex's Avatar
But the 310cc injectors are a good idea. It's better to have bigger fuel injectors than what you actually need. The lower you can keep your injector duty cycle the better off you'll be in the long run. You don't want to max out your injectors.
I am interested in this kit. What kind of turbine are you using?? Like someone else asked, can we get a manifold with a flange for an external wastegate?? What kind of core are you using for the IC?
Zach
Old Nov 25, 2004 | 09:37 AM
hotbox05's Avatar
dude it's all about a motor swap or the greddy kit. either way works for me
Old Nov 25, 2004 | 08:40 PM
kshymkiw's Avatar
OhioScions
numbers seem a little low. My D15 in my honda, with a junkyard kit, could put down 150+ and my D16z6 put down almost 200. 130....If you can get those numbers up to 150-160 at 8 PSI...then you have a good kit
Old Nov 26, 2004 | 07:48 AM
BoostedRex's Avatar
I still haven't heard any answers to my questions. I've been dealing with turbos for several years now. More info is needed before any of this is believable.
Zach
