xB Automatic trans fluid refill question
Old Jul 1, 2018 | 07:20 PM
Adidas's Avatar
Default xB Automatic trans fluid refill question
Over the last few days I've taken the lower auto trans oil pan off to replace the ATF fluid temp sensor. I've let the fluid drain for 3 days. A total of 8 quarts came out.
I've finished the job and refilled the trans with 4 quarts to test drive. With the engine warm I'm not getting an fluid on the stick.
Do I need to refill with 8 quarts total to match what came out or just 1 more qt at a time and check the stick?
Thanks.
Old Jul 2, 2018 | 01:36 AM
jct's Avatar
jct
add 4 more quarts the 4 you put in
Old Jul 2, 2018 | 01:44 AM
MileHightC's Avatar
Super Moderator
SuperMod
Run the transmission through the gears with your foot on the brake a few times and then check the fluid...I'm guessing you'll need to add some.
I don't know how you managed to get 8 qts. total as according to the service manual an ATF dry fill calls for 7.2 US quart.
kleecker
Mar 17, 2015 12:15 PM
KINGxOFxSKA
May 23, 2014 06:33 PM
saba
11
Oct 5, 2011 06:07 PM
Just_Bob
Mar 26, 2010 08:35 AM
gp1817
Oct 7, 2009 02:49 PM
