YARIS h.b. , XA , XB :same engine and manual transmission ?
manual transmission has the exact same gearing for 1st through 5th gear. But final drive ratio is different. I'm hoping the mounts would at least be interchangeable because I want a lower rpm for highway cruising!
For reference, my manual transmission drain plug has a white sticker on it stating "Refer to Owners Manual"
in Japan VITZ rs 1.5l uses same trans as US X.a. 8bolt final drive, The US / CDN market echos use the lighter duty trans shared with the small engine 1.0l Vits a 6 bolt final drive
echo c150n trans
scion c154n trans
here is it on echodriver
http://www.echodrivers.com/forums/vi...ht=lsd&start=0
echo c150n trans
scion c154n trans
I would believe they are the same fitmint as a echo/XA are the same chassis and the ECHO in other markets came with the c154n trans
I dont know if the NEW Yaris comes with a c150n or not sorry
evolving_machine
Oct 21, 2023 01:16 PM
