Aftermarke Intake Air Temp sensor
Old Mar 29, 2009 | 03:43 PM
xa007xa's Avatar
Default Aftermarke Intake Air Temp sensor
Does anyone know if I can use an aftermarkert IAT sensor by connecting it to the stock IAT wire so that the stock ecu can read temp? I want to put the sensor on my intake manifold.
Old Mar 29, 2009 | 04:23 PM
draxcaliber's Avatar
isn't that what the MAF sensor does? and it will tell you if you just plug in a scanguageII into the OBDII port?
Old Mar 29, 2009 | 04:27 PM
xa007xa's Avatar
you're missing the point! I want my intake air temp at the intake. not before my intercooler and not before my weapon-r intake manifold that is subject to heat soak.
Old Mar 29, 2009 | 07:37 PM
xa007xa's Avatar
the resistance range of the stock IAT sensor is 98.5 ohms to 156K ohms. What I'd like to do is find an aftermarket sensor that has the same resistance range as the OEM sensor and just wire it up to the factory harness. The other option would be getting a second OEM MAF and using that one for the intake air temp and the primary one for air flow. However, that seems like more work than i want to get involved in. Any ideas are welcome.
Old Mar 29, 2009 | 08:47 PM
jct's Avatar
jct
why not use both MAF and MAP sensors theres plenty of cars out there that use that set up
Old Mar 29, 2009 | 08:56 PM
xa007xa's Avatar
have a map sensor!!!! people: please help me out with what I want to do. the PROBLEM is that the stock ecu is calculating fuel based on erroneous information. if my intake manifold heat soaks the air it will cause a rich afr which is what I am trying to avoid!!!!
Old Apr 3, 2009 | 08:02 PM
DeiselFuel2o2's Avatar
Just get an electronic thermometer and solder it right behing the cone filter in the intakes tubing. They are relatively small and it will not read outside air temp, but intake airtemp. The heat soak will effect the airs temperature but you can calculate the medium and use that as your True Air temp and see if it runs rich or lean.
Thats all i can think of.
Here's a link to your best shot!
http://web5.automationdirect.com/adc...FYJM5Qod6E80YA
good luck
Old Apr 3, 2009 | 08:06 PM
http://web5.automationdirect.com/adc/Overview/Catalog/Sensors_-z-_Encoders/Temperature_Sensors/RTD_(PT_100)_Probes_-a-_Thermowells
This would be your best bet!
Old Apr 4, 2009 | 01:05 PM
xa007xa's Avatar
thanks for the suggestion. ultimately i want to move my intake air temp sensor to the manifold, but im going to focus on more pressing tweaks right now.
hampton1100
May 28, 2015 07:32 AM
Aroxguns
Mar 20, 2015 10:06 AM
miguelishu
Mar 9, 2015 02:38 AM
hotroddelux
Dec 3, 2014 11:33 PM
eric_m
79
Mar 17, 2013 12:21 AM
