APEXI NEO DONT WORK ON
Old Feb 7, 2007 | 08:02 PM
ALEXB06PR1's Avatar
Default APEXI NEO DONT WORK ON
I WANT TO KNOW IF APEXI NEO WORK ON SCION TURBO TO TUNED OR NOT
I HAVE A DISS THAT SAID DONT WORK TO TUNED WELL ON XB TURBO
WHY ???
Old Feb 7, 2007 | 08:06 PM
Tribalboy04's Avatar
CAPS LOCK
Old Feb 7, 2007 | 09:44 PM
RHDVIPbB's Avatar
Scion Corps
After trying to decipher your question I might have an answer.
It depends on if it is wired properly. If I were you I would probably go with the Greddy Emanage. It will do what the Neo can do and more. Plus it has been proven to work with the xB ECU and even on turbo boxes.
Old Feb 7, 2007 | 11:34 PM
IH8ONYU's Avatar
the 06 ecu has a differnt pinout then the 04-05 models - FYI make sure you have the correct ecu pinout for your year.. i posted the 06 pinout, if you use the search its posted as "1nz-fe 2006 ECU pinout posted" in the 1st gen owners lounge.. the 04 05 pinouts are posted all over the site, use the search
Old Feb 8, 2007 | 08:45 PM
ALEXB06PR1's Avatar
sorry thats not my question the question is can i tunned a xb turbo with a apexi neo or not
Old Feb 8, 2007 | 09:43 PM
RHDVIPbB's Avatar
Scion Corps
Originally Posted by ALEXB06PR1
Sorry thats not my question. The question is can I tune an xB turbo with a apexi neo or not?
Fixed your spelling. Yes you can do some tuning. Mostly air and fuel. I haven't used the new Neo, but if they are like the past SAFC then you are able to work on the xB to a point.
Old Feb 8, 2007 | 10:00 PM
Simmo's Avatar
Fixed your spelling
Sorry, 24 year old should not have that kind of spelling.
Anyways, to answer our question - Yes you can. You should already have some kind of engine management installed with your turbo. If not, then you can use Neo, but I would suggest greddy emanage, if that isn't enough for you, go with emanage ultimate. I am a stong believer - your turbo is only as good as its tuning.
Old Feb 8, 2007 | 10:20 PM
RHDVIPbB's Avatar
Scion Corps
Originally Posted by Simmo
Fixed your spelling
Can't understand how someone can have bad spelling when asking a question.
I agree that you should have already gotten Emanage with your kit. It will supercede the Neo since it does the same function and more. I hope you weren't trying to do a budget build since the emanage is just a little bit more than the Neo.
YooItsJay
Dec 2, 2015 08:13 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
TheRedBox
15
Jul 9, 2006 04:08 PM
Infiz
Nov 2, 2003 11:32 PM
onesicbowtie
Oct 8, 2003 02:50 AM
