Built motor update(final Greddy results pg.3, img pg.4)
Old Sep 7, 2009 | 02:39 PM
08_Scion_tC's Avatar
Very nice numbers, you have any pics of the built motor?
Old Sep 7, 2009 | 06:21 PM
blown_xa's Avatar
Originally Posted by xa007xa
believe me... i tried everything to get EMU to scale back the 440's. AEM Tru-Boost @ 90% duty cycle only puts out about 12psi. I even got 2 full turns on the actuator arm to shorten the throw of the wastegate. I have a FMIC... so maybe i'm losing 1 - 2psi because of that fact. I'd say that my biggest problem is the stock ECU.
Exhaust is stock with Greddy SP2 Axle back.
ok i see. I would get a 3" down-pipe back exhaust made for your car, the factory 1 5/8" will create an extreme amount of back-pressure against the exhaust turbine. Im willing to bet you will pick up 4psi at least.
As far as the injector scaling, im not sure
Old Sep 7, 2009 | 06:22 PM
blown_xa's Avatar
ill try to get some up tonight
Old Sep 7, 2009 | 08:05 PM
Cool
Alright cool.
Old Sep 9, 2009 | 02:29 AM
Sciond's Avatar
Old Sep 9, 2009 | 02:30 AM
Still no pictures?
Old Sep 9, 2009 | 03:45 AM
JSosa's Avatar
running with the big boys, i LOVE it!!!! I got rid of my xA, about a month ago because i moved to the US and bringing the car with me was going to a pain in the a$$.
I never knew that it would have been strong enough to run with Z's... I used to run the car when i was NA, but i was never able to run it turbo. Im glad to see this and it makes me wish i didnt sell it :'(
Old Sep 9, 2009 | 11:58 PM
blown_xa's Avatar
cant find my darn camera lol.... ah ur in the us now, where at?
Old Sep 10, 2009 | 03:17 AM
blown_xa's Avatar
another video, this was in the wet. Still wastegate boost 137whp, Toyo R1R's do great in the rain as you can see I have no problem keeping up and even passing awd cars
http://s52.photobucket.com/albums/g5...7-VID00003.flv
Old Sep 10, 2009 | 03:24 AM
Very nice video.
Old Sep 10, 2009 | 11:31 PM
blown_xa's Avatar
http://s52.photobucket.com/albums/g5...walkaround.flv
Old Sep 11, 2009 | 02:23 AM
xa007xa's Avatar
forgive my ignorance....but how is a 3" exhaust going to give me more boost if the the wastegate cracks at 12psi with the boost controller at 90% duty? Wouldn't I get more boost with an 11psi wastegate actuator vs. the 5psi that came with the kit?
Old Sep 11, 2009 | 02:45 AM
blown_xa's Avatar
I would shy away from setting the crack pressure any higher than 5psi, it will result in boost fluxuation. The tdo4 turbo spools quick enough to where you don't have to worry about that.
at 90% duty cycle, you are in a sense running a closed wastegate. It gets no boost pressure signal because the boost sylinoid is bleeded off all the air. It won't matter if you change to a 11psi actuator at 90% you will end up in the same boat.
Your turbo must be able to breathe, it is a fan. of you put a sheet in front of a fan it spins faster working twice as hard but produces less flow correct? Same concept with a turbo. Between shortening the intake and going with a 3" exhaust, that is how you get more boost when maxing out a turbo.
I still have the 5psi actuator, the same one you do. And with my boost controller off im between 9 and 10psi. With the original Greddy intake set-up and stock exhaust I would be at 5psi. It's all about efficiency.
Old Sep 11, 2009 | 12:10 PM
xa007xa's Avatar
I see. thanks for the explanation. definitely have to do my exhaust, but also considering a different turbo.
Old Sep 11, 2009 | 06:29 PM
Man I your video's, make me want to get an xa just for my daily.
Old Sep 11, 2009 | 09:49 PM
Just1n's Avatar
Wagonistas
damn.That egg scoots.
Old Sep 12, 2009 | 12:05 AM
blown_xa's Avatar
Thanks for the positive feedback! Im going to do a few more events and put more miles on the motor, if all is well Ptuning will be offering the 1nzfe shortblock.
I am looking forward to going to the dragstrip, I really want to break into the 13 second barrier.
I may wait until it gets cooler because the last couple of days, my power has definately risen do to the cooler weather. I actually hit almost 24psi today when I took a customer for a ride, it hit timing retard (we set up the tune that way) and I turned the boost down. It pulls really hard, I think if I put my car back on the dyno in the winter it will be over the 180whp mark and over 200ft.lbs of torque.
If you see in the video, the air filter is up where the rain gutter used to be. I just fabbed up that intake 2 days ago, im already noticing cooler charge temperatures. I am going to go one step further and make a air box to isolate the filter from any engine compartment heat, it will draw in the air from the cowl cover.
Old Sep 14, 2009 | 03:46 PM
crxgames's Avatar
Glad to see someone did this. I've been thinking about doing something similar for a few months now...just haven't gotten around to it lol.
Old Sep 16, 2009 | 01:36 AM
blown_xa's Avatar
looks like I will be hitting up the quarter mile this weekend, Ill be sure to post up some numbers. Ill try to get some footage also.
Old Sep 16, 2009 | 02:47 AM
Sweet can't wait.
