Pre Turbo Questions
hey guys i would really like some help wit this, i would like to know what i should do to my engine in order to be able to run a turbo at somewhat of a decent psi range. i would like to do some work on the engine first, but i would like to do work that would be turbo oriented. ive already planned on doing the clutch and flywheel, but i dont know what to do with then engine. i just need some help. also ive already planed on changing out the fuel pump for something a little bigger, in the process of finding out what i could put there. but any and all HELP with the engine stuff would be most appreciated, thankx
minimally, you'll need to a return line, new injectors, higher output fuel pump, oilline in/out, a piggyback for the ECU that will override the OEM settings and not revert back, and if you plan on over 6 psi, rods, pistons and bunch of internal work, just to name a few of the mods.
Team No Limitz
Team No Limitz
And Vito had a really nice set-up also!
bootlgr
Jan 26, 2016 01:22 AM
my06tc
Jun 25, 2015 12:18 AM
