What is Max boost being put out so far on the stock xB motor
supercharger is still spooling just as much as long as the crank is spinning at a given rpm... im not exactly sure but im guessing it bleeds the other 6psi because of a throttle vacuum line?
-jon
-jon
Team No Limitz
Originally Posted by krazylowgsx
is anyone running a FMIC? its even harder on the motor with out one. nothings worse than forcing HOT air into a N/A motor! Thats asking for the death bed!
-jon
-jon
if your cruising down the highway at say. 3500 rpms, how are you in boost? your only in boost when you are accelarating. so if the cruise control is on, or your just driving a steady speed, your not in boost! its just not possible. check your boost gauge while cruising.
and i don't see a problem running 12 psi on the XB motor every once in a while. but i would have to agree, forged internals are well worth the money. 12psi all day, everyday would kill our motor very fast! is anyone running a FMIC? its even harder on the motor with out one. nothings worse than forcing HOT air into a N/A motor! Thats asking for the death bed!
Man, i feel like a total idiot. For some reason i was thinking he had a tubo. Of course the s/c will have boost because its belt drivin so you are right... if the crank is turning, so is the s/c!
Now a turbo is a diffrent story. I own a 97 Eclipse GSX, and i built this baby from the ground up. while vruising at highway speeds, a turbo is not in boost.
i didn't mean to jump in like king ____. sorry for the confusion.... i thought we were talking turbos
Simplyscion....if thats your ride, that is a nice ___ set up. However, i'm not digging the accordian looking pipe up top. looks tacky as hell. is there any way to swap that for a hard pipe?
Team No Limitz
Simplyscion....if thats your ride, that is a nice butt set up. However, i'm not digging the accordian looking pipe up top. looks tacky as hell. is there any way to swap that for a hard pipe?
Ok... Why is it that everyone that does these HUGE posts, are always the ones that are N/A? I find that to be rather funny.... I am up to 5-7psi daily depending on how I feel.
As for forged internals, the factory rods ARE forged. If you dont believe me, stop by and look at the one I have in my hands.
As for the not making boost at a cruising speed, that is correct with a turbo. At constant speed, you are NOT making any boost. You are in vacuum.
Team No Limitz
just run 7 psi but then again sometimes 7 might be to much it all depends on the tunning i would recomend using a hks fcon vpro or something to that extent the better you can control everything the more reliable everything becomes
Originally Posted by SnakeXB
Originally Posted by dgHotLava
Originally Posted by Spider13
I am pretty sure Matchbox gets up around 10 with no problems so far.
have been doing so for about year with no problems (except a burnt out clutch).
if I can run 30 psi on a stock neon motor im sure this motor can handle 12psi daily
thanks for the info guys, but your all running small turbo units, anyone running something with some high cfm numbers
i run 8 psi all day evry day, and anyone from this area can verify i beat the hell out of my car. On the track i have done two full passes at 12psi, but i was HEAVILY overfueling the motor and bogging to the point where my 60' were in the 2.5 range lol. (a/f gauge wasnt responding correctly and i programmed my neo extra rich to be safe. I have since then tuned my vehicle a little further and will be running tomorow at Lebanon Valley. If i can, i will try and get someone to tape a few full passes.
My lord!! There is so much misinformation and myth in this thread that it's sickening!!
I guess having a boosted Civic for the last 3-4 years has taught me a lot. I suggest some of you people do some TECHNICAL reading before basing your opinion on he-said, she-said info.
carid
Dec 4, 2014 09:35 AM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
EV_AIC-xB
11
Oct 10, 2003 07:28 AM
