06 xA Noisy AUX - should I go to dealer?
Old Feb 23, 2006 | 06:52 PM
dxt178's Avatar
Default 06 xA Noisy AUX - should I go to dealer?
Hello All,
I've recently installed a Sirius radio into my 06 Scion xA and noticed the horrible engine noise (alternator whine/ground loop type noise) it does fluctuate with the RPM's of the engine. (I've changed cables and rerouted the cables with no change in noise)
Now, I've read around here and on the net about this being a fairly common problem. Here's the question: The dealer said they would take a look at it, but that they were not aware of any issues. Is it even worth my time? Has anyone else had any success with the dealer fixing this problem?
Thanks!
Old Feb 23, 2006 | 07:45 PM
midtowndesi's Avatar
i am using a gold plated aux cable to connect my laptop to the stock head unit on my xB. i've had no issues at all. definitely take it to the dealer because it may be a known issue (as it is apparent on this board.)
Old Feb 23, 2006 | 09:32 PM
DJ_SpaRky's Avatar
Please search, this has been covered before.
Old Feb 24, 2006 | 05:07 PM
dxt178's Avatar
Maybe you missed the entire second paragraph I wrote in my OP, but I *have* searched this site and others and read up on what has been said. My question is if anyone has actually had the problem FIXED by the dealer.
I'm well capable of installing a ground loop isolator and being done with it, but that wasn't my question.
Old Mar 3, 2006 | 12:23 AM
jgriff63's Avatar
Default nope...they know nothing
Had mine checked out...they said go buy a ground loop isolator and they'd install it for me.
Old May 10, 2006 | 04:02 PM
Fsu1dolfan's Avatar
Did the grouund loop isolator work for you.....i have the same problem....i am curious if it is because i am just using the cig lighter plug instead of hardwiring it for power!!??
Old May 10, 2006 | 04:35 PM
I am connecting my laptop to the aux audio port and getting power via the cig lighter and ac converter... im not having any problems.... just an fyi
- sh00k
Old May 12, 2006 | 03:33 AM
cain96's Avatar
I have a sporters installed in my xB to and get the same engine noise and have yet to find a solution. I'm taking mine in to the dealer this weekend.
Old May 12, 2006 | 01:18 PM
Fsu1dolfan's Avatar
let me know how it goes and whats the solution!!!
Old May 12, 2006 | 06:01 PM
Forklift's Avatar
we have had that issue with alot of the XM and Sirius units with factory style aux inputs, most require either a different ground(to the radio chassis or wire) or a ground loop isolator
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Luisfc1972
Sep 30, 2015 12:22 PM
user9430961
Sep 24, 2015 01:09 PM
