Auto Down Window Switch possible on all Windows?
Old Dec 22, 2005 | 03:54 AM
  #41
tbone587's Avatar
For my car I have auto up and down on all switches on the driver side. I put in the dei 530t modules on all 4 windows.
Old Dec 22, 2005 | 04:11 AM
  #42
SmartAss's Avatar
Thats what Ive been saying from the begining.
Old Dec 22, 2005 | 07:46 AM
  #43
bBOXD's Avatar
How much does something like that run?
Old Dec 22, 2005 | 07:54 AM
  #44
magicmanjk808's Avatar
Originally Posted by SmartAss
Just get window modules put into the car so you can roll them down from a keypad and it also changes them to 1 touch rolldowns and ups. Ill do it for anyone for about $200 for all 4 windows.
seems like a good deal. if i had money, i would do it. mark if you still want the garsons keyless jewels, pm me.
Old Dec 22, 2005 | 03:04 PM
  #45
sprslug_182's Avatar
Originally Posted by ecandlcubed
just curious, you don't need some sort of controller to stop the motor once the glass hits the bottom? wouldn't motor keep winding the window down similar to me keep holding down the button?
No, a way to check this is, to push and hold your window switch down while you have your headlights or your dome light on. When it reaches the bottom, a voltage spike will cause the lights to dim and the motor will know its at the bottom. The relay inside the window switch will recognize that the window is down all the way because of this voltage spike. The same thing happens with the auto down buttons as well.
Old Dec 22, 2005 | 08:50 PM
  #46
rebelMan's Avatar
KAD
I've been looking for info about this. Thanks for all the info in this thread
Old Dec 23, 2005 | 12:33 AM
  #47
1epoXyBox's Avatar
Bah bah bah does anyone listen. DEI window modules. cost about $40 for 2 windows so $80 and some wiring knowledge and you will have auto window up and downs.... Plu syou can hook it up to your keypad and yes even your factory keypad.
If anyone is interested, heres a link to an RSX DEI 530t DIY install:
http://forums.clubrsx.com/showthread.php?t=177722
Old Mar 9, 2007 | 02:36 AM
  #48
Fran82's Avatar
Back from the dead!!
I was just in a Lexus GS the other day and noticed that all of the switches throughout the car allow auto up/down. Saw this thread and was wondering if anyone else has looked into converting. I know about the DEI module, and might end up using that, but I'd like to try it with factory switches if possible. The Lexus switches all have a slight detent at the upper and lower movement to engage the auto feature.
I think the DEI modules have a voltage sensing circuit which stops the windows from crushing someone on the up movement, so it can't be that hard for an OEM to do. Never made sense that you can auto down to pay a toll or order at the drive through, but when you have your food in hand or start to drive on the highway again, then you have to hold the button while the window goes up. ???
Old Mar 9, 2007 | 02:49 AM
  #49
djct_watt's Avatar
Team Sushi
A lot of Toyota's/Lexus's have this. . . the tC has auto up/down on both windows as well.
Old Mar 9, 2007 | 02:36 PM
  #50
Fran82's Avatar
I know a lot of Toyota products have this feature, I'm just trying to clarify if anyone has successfully equipped an xB with it. I know the DEI modules will work, but want to see if using factory switches alone will allow it, or if there is an external module used in the Toyota system also.
wonderworm
Nov 19, 2023 01:44 AM
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
IrjI619
Dec 21, 2014 05:04 AM
pier0723
Dec 3, 2014 03:38 PM
oj411
Dec 27, 2003 05:51 PM
