Bazooka Sub ?
so i was thinking about buying the 8"bazooka tube from trdsparks.com but i wasnt sure if i need to get the wiring harness with it i know it sounds like a dumb question but i wasnt sure if the sub it self came with the harness or not so anyone who has ordered one can you let me know and please dont tell me to buy something else because i cant really put anything else back there because need all the space i can get but the extra kick to the radio would be nice but any feed back is apprciated thanks
Yep, it comes with everything. Even has templates for cutting the rear cargo mat. Has instructions/templates for both xA and xB.
One word of caution. If you follow the directions using the template they provide it puts the sub in the middle:
https://www.scionlife.com/forums/viewtopic.php?t=142890
I have since moved it to the left as it should be. Be sure to slide the template over to the left so that the sub is in line with the plastic loop cover thing on the back of the rear seat on the drivers side. I just finished installing one in mine so feel free to PM or IM if you need any help.
Has anyone thought about taking the factory sub and mounting it in the storage area on the right side of the cargo space?
You could remove the foam insert tray, fabricate some brackets, and install the sub. Granted, the sub wouldn't be flush w/ the floor but it would be a lot lower then it would be if you installed the way Scion wants you too!
Also, then I could install a rear strut tower bar! hmmm..
thoughts?
thoughts?
Originally Posted by chadfo
Have you thought about an underseat enclosure?
Is the xb pre-wired for the bazooka or do you have to run your own wire from the head unit all the way back? I was just going to T-tap the one of the rear speaker wires for my signal and run power and ground. Any input would be great.
S3X
May 27, 2004 07:01 AM
sithscripter
Mar 31, 2004 04:02 AM
