A/C HELP!
Old Feb 21, 2007 | 12:49 AM
ReyS739's Avatar
Default A/C HELP!
Ok I did the LED mod behind the HVAC unit and now my A/C on my 06 xa is not working it doesn't turn on. It has to do with the contacts cause I took out the 3 spoke metal thing and tried it on the copper piece and it turns on....but when i put everything back to gether it donesn't turn on.
here's a pic of the 3 spoke metal thing making contact with the copper...
Old Feb 21, 2007 | 05:09 AM
TerribleTed's Avatar
That unit is a little spendy if it is broken.. I think I priced it at $117. Hope you can fix whatever you did.
Old Feb 21, 2007 | 12:11 PM
ReyS739's Avatar
Ok I did some research and it seems I'm missing a spring in this assembly...is that correct???
Old Feb 21, 2007 | 01:27 PM
Dunno for sure but a spring that helps the contacts stay together makes sense. The problem is going to be if the spring is lost getting a correct replacement could be hard. Scion sells this unit as an assembly. The good news is that the switch unit only lists for $78.48 instead of the $117 I listed above. (the other switch assembly there lists for $117). Hope you can find the spring.
Old Feb 21, 2007 | 02:34 PM
ReyS739's Avatar
Thanx haven't found it but I think a trip to the junkyard might be nessesary....
Old Feb 21, 2007 | 06:50 PM
Good Luck!!!
Old Feb 22, 2007 | 11:42 AM
ReyS739's Avatar
Tell me about it I called about 1/2 a dozen and no one has scions....oh well I found a spring that worked It's not OEM but it got the job done.
Old Feb 22, 2007 | 12:47 PM
SWEET!!!
Old Feb 25, 2007 | 06:55 AM
the_used_1909's Avatar
Default lol
the same thing happend to me luckily it hit my foot when it fell i didnt know that was what it was for until i tried to start my ac fan and all i heard was clik click lol you can use any old spring that will fit good luck
oh and where did you get the leds that you used havc?i want to do mine in pink =)
Old Feb 25, 2007 | 10:35 PM
ReyS739's Avatar
http://autolumination.com/74.htm but I'm trying to use something else b/c the edges get real dim.
Old Feb 26, 2007 | 12:14 AM
Thats because the way the light is distibuted it by that plastic ring and i dosent go all the way around i have the same problem i think you can get super bright leds but you need to use resitors to get the to work =) keep me aupdated please iam intrested if it works out for you so i can do mine =)
Jus2tastee
Oct 1, 2015 08:57 PM
jnesselroad
Sep 15, 2015 06:57 AM
BlingSlade
Sep 5, 2015 08:52 AM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
