Daytime Running Lights experience - Canadian conversion
Old Nov 22, 2007 | 05:06 PM
  #41
TheSaint77's Avatar
Moderator
Moderator
Default Re: Does not seem right to me
Originally Posted by mitcheroo
This set up does not seem well done to me. Time to exercise your consumer rights, buzzing noise does not cut it.
I notice you are BBY, Burnaby I assume. Which Cdn Tire did you go to so I can avoid it for my federal inspection?
Thanks
I wouldn't worry about the Fed Inspection too much. Mine took 3 minutes. They check the gauges to make sure they work, looked at the mileage and made sure the lights came on when it started up.
I couldn't believe I waited 2 weeks for a 3 minute inspection.
Old Nov 23, 2007 | 01:23 AM
  #42
mitcheroo's Avatar
Default Headlights only
My understanding is that the headlights should go on. Someone else posted the link to the actual regulations. My interpretation is that the regular headlights can be at 100% or 60% or the high beams can be at 60% but if you want to read them for yourself that would be better. So here is the link.
http://www.tc.gc.ca/acts-regulations..._Running_Lamps
Good Luck
Old Nov 24, 2007 | 03:54 AM
  #43
Reactor's Avatar
I am 75% done with this project. Only my low beams come on with the ignition ON and no other lights or buzzer are affected. The low beams are at 100% at this time, but i am waiting for the resistor i ordered to lower the output. The cost of parts so far is $5 for the universal relay, some spare wire (about 1ft) and $7 for the 0.5 Ohm 50 Watt resistor. I may add a switch to disable the DRL when the resistor gets here and i finish thhe installation.
Old Jun 15, 2009 | 07:48 PM
  #44
michaeltag's Avatar
Default Daytime Running Lights experience - Canadian conversion
It is a real bummer that it is so complicated to do this conversion for my Scion xB. When I did it for my '96 Miata, the Canadian and US cars have the same wiring harness so, the DRL's are accomplished by simply plugging in a relatively inexpensive part that is reachable near the steering column under the dash. No removal of anything. The DRL's use both filaments of the 1157's in the parking/turn lights so the headlights aren't involved and they turn off when the handbrake is applied, etc. Of course, that car has the barn door hidden headlights, so it's a good thing they don't use the headlights.
Does anyone know if there's a conversion that utilizes the parking/turn lights instead of the headlights for the Scion? I wonder if it would be bright enough.
Old Jun 18, 2009 | 01:27 AM
  #45
low_down_xb's Avatar
im sure you could just connect the wires to the turn signal bulb instead of the headlight, i wouldnt see why you couldnt
Old Aug 23, 2009 | 02:04 AM
  #46
Rick Auricchio's Avatar
I have just done a parking light conversion on my wife's week-old xD. Because it's only the parking lights, I'm sure it won't pass Canadian standards, but it does provide forward light, which meets my needs.
About a dollar's worth of parts (four diodes) does the trick. The parking lamps come on with the ignition. Normal headlight/taillight/signal operation is not changed from the original.
I was able to mount the diodes and minor wiring changes inside the relay/fuse box inside the engine compartment on the driver side. I cannibalized a spare connector I had, so I didn't even have to cut or splice any of the original wiring.
If there's interest, I'll draw up the mod and take photos.
Old Feb 7, 2012 | 12:32 AM
  #47
lotus's Avatar
Default Hamsar DRL install
Hi,
Wondering if anyone could provide some pics and a step by step of the hamsar drl install. Trying to do min and only getting the drivers side parking light comming on. Any help is much appreciated.
daniinpitt
Apr 4, 2015 08:07 PM
scsteven
Jan 25, 2015 01:06 AM
carid
Jan 8, 2015 11:33 AM
amart
Scion xD Aero & Exterior
Dec 23, 2014 12:06 PM
Pirate183
Nov 29, 2014 07:37 PM
