View Poll Results: Yea or Neah?
Voters: 8. You may not vote on this poll
DIY: Change Your Climate Panel Color
Hey everyone I was Really bored so I decided to pull my box apart and change stuff. I wanted to change the color of my AC/ Control *****.
Tools needed: Phillips Screwdriver
Small Flathead Screwdriver
Two Hands
Sharpie (any color that floats your boat)
here it goes..........
Start out by removing the center controll panel by removing the left and right ***** and taking out the screws then pulling from the bottom by the ashtray. Once the panel is removed (be sure to unplug the three conectors). You'll be left with this......
The red arrows point to snaps that need to be depressed to remove the main unit. Once removed ......
You'll need to use a small flat head screwdriver to remove the lights(hint: the red arrows are pointing at them). Once out they look like this....
If they dont look like this u messed up. Anyways you'll want to carefully remove the yellow covers. Then color them to suit your fancy. If you colored them red u can put those yellow covers back on them, it doesnt effect the color or brightness. Then put everything back together, and if you chose to do it rec it'll probably look like this......
And the best thing about it all, if you do it and wanna change it back or change the color just put some rubbing alcohol on a cotton ball and clean off the bulb.
Thats it for now. I've got some red vinyl overlays coming from bluebatmobile.com so I'll post pix and what not when I get 'em.
Two Hands
That sucks!!! Well here's a link to a photo album with all the pix of the install.
http://www.imagestation.com/album/pi...?id=4287046903
I like the way it looks although I am never comfortable with the SHARPIE technique. It's PERMANENT marker. Key word being PERMANENT , and these bulbs don't seem to be easy to replace.
mrsocks
Jan 20, 2015 01:29 PM
DirtyThirty
14
Jan 16, 2004 04:48 AM
wonderworm
Nov 8, 2003 05:42 PM
