DIY side mirror turn signals
have you guys done it? and where and how do you tap into the side markers? or is that where you even splice into? help please.
I personally would use an inline wire tap with the side marker lights, but I haven't tried putting the LED's behind my mirror yet. Just make sure you use the right resistors for your LED's or you might blow a fuse and/or LED's.
Originally Posted by peabe
im just trying to figure out how to tap into the sidemarkers. i cant figure out how to get into the fender
https://www.scionlife.com/forums/vie...?p=56761#56761
The applicable part of the instructions reads as follows:
Originally Posted by translated Japanese instructions
14. Pop the side marker out of the fender. Connect the supplied T-connector wire harness to the wiring for the side marker.
15. Feed the long end of the T-connector wire harness through the back side of the fender and UNDERNEATH the weather strip of the front door. Use the supplied foam tape to secure the wire at the point BENEATH the weather strip.
16. Connect the end of the T-connector wire harness to the connector attached to the LED blinker mirror cover.
I think I'm going to try the JDM instructions by going in through the sidemarker hole.
Anyone have experience with tapping into the sidemarker wire?
RPM
xBSciontist
Jun 18, 2019 03:06 PM
minter66
Dec 15, 2014 01:45 PM
Opr8r
20
Feb 25, 2004 11:29 PM
