Fog Machine
Fog Machine
Hey guys do you think id be able to install something like this or sumthing similar underneath my XB thats lowered 2"? u think itll work? smoke machines r tight
http://cgi.ebay.com/ws/eBayISAPI.dll...category=14984
i guess....if u used a power invertor...but it would only work when u r sitting still. Plus if u used it on the street, everyone would think that your engine was blowin up or sumthin....IMO...not cool....maybe at a carshow
be careful
be careful with fog machines. They use alot of watts and 120volts. and with most power inverters you get around 150watts and with anything higher 10 minutes will drain you battery. And yes if you use it on the road you wont see anything. in fact it will only work on non-windy day. Also fog machines can take up to 20 mins to warm up before they will fire.
well if your going to
Add another battery if you havent already done so.
You can hook a plastic tube to a fog machine to rediret it outside the car.
Are you sure you want to put that big of a hole thru you body pan?
Be aware that it uses fog fluid and the liquid spills out so do mount it next to amps or speakers.
first of all that price is way too high id' say $80 at the most is a fair price for a 700 watt fogger. you might be able to mount it but you will have no access to the fluid tank. as far as power goes the fogger will draw 5.83 amps of ac current. i say just bring it to shows and set it up around the car.
Re: Fog Machine
You could use liquid nitrogen as well, but it requires a special container to carry the stuff around.
George
Re: Fog Machine
Originally Posted by George
What you need is a pan of water and a chunk of dry ice. No power required at all, and the fog is just CO2 and water vapor so it won't leave residue on your car or the surroundings.
George
But if you really want to screw with someones head take a 20oz bottle of dry ice and water and pour it out as you driving down the road and freak out the people behind you.
Better yet put a strobe light inside and stick a biohazard sticker on your rear windsheild. When you get to a stop light turn on the strobe pour out the dry ice and have two guys jump out of the back in bio-suits and run in opposite directions and drive off. (Dont forget t pick up your friends later!)
Re: Fog Machine
George
George
sIcKsCiOnS
If you really need to have a low lying fog, I would suggest a American DJ MisterCool. It uses ice and a smoke machine to create a low lying fog. It's a great effect. I use them for Halloween displays for the holidays. Currently on eBay for about $179.00.
Good luck.
Good luck.
OpTicaL
09-16-2015 10:25 AM
BlingSlade
09-05-2015 08:52 AM
Subaru86
07-31-2015 04:00 AM
