ghetto bazooka
sIcKsCiOnS
I have a really ghetto 8'' walmart sub that looks sorta like a bazkooa sub, anyway my friend gave it to me cause he got 2 10s and a nice amp. question is, I wanna put it in just for ____s and giggles, how do i wire it in without cutting anything or doing anything major
Well I think the problem is that you need to be a little more specific...Do you know a brand? Maybe some pics of where the plug is for the "amp". If it is a regular bazooka I think there is a prioritary plug that connects right into the stock HU...More info is needed!!!
Just get some tap splicers and tap it into the wiring for one of your rear speakers. Just match what's there. There's enough wire at the speaker plugs to tap...
It adds a little, not much.
I paid 8.99 at Kragens for mine
:oops:
Figure I'll either replace it eventually or come across a cheapo amp and toast it up...
sIcKsCiOnS
thanks man, i might as well do it, what the hell its free, but one more question, where is the wire for the rear speakers, can you get to it from the tail light access panel thing"?
Yeah. Remove the spare and stuff. Pull the plastic trim off the bottom of the hatch opening, take the two bolts out where the cargo cover clips on, and then just pull it out a little. I found it wasn't worth removing the seatback to get extra space on that, unless you're not used to working in a tight space. I ran the wires out the bottom and into the crack behind the backseat. I used a strap to secure the tube, but if I need room, I can just loosen the strap and its got enough wire to put it in the floorboards or whereever it needs to go...
S3X
May 27, 2004 07:01 AM
sithscripter
Mar 31, 2004 04:02 AM
